Thread: signum noise
    Regular Member eaglepva's Avatar
    Up North
    Default signum noise
    Hi,
    I have been reading through the pages on the problems with the signum noises with intrest as i have a creaking noise coming from the front of my car. But i am unsure if it is covered by warranty as my car is a 2004/53 plate model should the work be covered by vauxhall or will i have to pay for it to be done myself.
    Nearly forgot.
    I have only just found this forum and it is great all the info and tips that you have got are brilliant. so keep up the good work lads.
    Ashley.
    Full Member Big Sig's Avatar
    When is it creaking? When going over speed bumps? If it is its either the anto roll bushes or anti roll bar links. I doubt it would be done under warranty dur to them possibly being wear and tear items, but its worth asking
    Up North
    Mainly creaks when pulling off or when driving very slow and over speed bumps.
    Yep thats what it will be. Give them a spray with a silicone based oil and see if they get quieter, if they do then have them replaced, not too expensive, £10ish each for the bushes I believe. Just a bit tricky to do. Mine did it and it was worse on wet or cold days and if both wheels went over the bump at the same time, if one went over it before the other - approached on an angle - then it was much quieter
    Up North
    Thanks for your help m8
  1. Signum 3.0 cdti noise when cold
    By bigbazk in forum Engine & Drivetrain
    Last Post: 15th June 2012, 14:37
  2. Noise from the 3.0CDTI Signum
    By simsr4 in forum Engine & Drivetrain
    Last Post: 21st April 2011, 22:01
  3. Creaking noise from the back of Signum
    By rogerbrown in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2008, 21:31
  4. noise from rear of signum
    By mike56 in forum Suspension, Wheels & Brakes
    Last Post: 9th February 2008, 14:29
  5. Signum Road Noise
    By decho in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2006, 02:09
