Results 1 to 10 of 14
Thread: DTI or CDTI
    Shropshire, England
    Default DTI or CDTI
    Hello,
    The web is full of the expensive problems of modern common rail diesels. Bearing this in mind, which of the above would be more likely to be reliable in the Vectra? I know it's all relative but the dti in my Astra has been fine.
    Best
    I think you can sum it up as... if you get a good 1.9 CDTi then keep it, it'll be a corker.. if you get a bad one, be prepared to sell it no matter how attached you've got to it..The DTi's seem to fair better but they are a much less stressed engine and therefore produce less power.. each has their problems..CDTi's seem to be fuel injection related/turbos' DPF's/ Inlet manifolds wheras the DTI's are normally boost hoses/ injector leakback pipes/boost sensors..
    Nicking Ya Dinner.
    If you decide to get a DTi again, do not test a CDTi, or you'll never want a DTi again.
    Regular Member ion's Avatar
    walsall
    As Mark said, the cdti's seem to depend on your luck.
    I've had one & done nearly 40K miles with one warranty repair that was done without problem, otherwise it's been perfect, & I know others who've had no problems.
    Equally though if you click for a bad one it will be a nightmare.
    My DTi never missed a beat
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I had a DTI and the pump went, cost £2K to get it all sorted (including towing). So DTI problems are far from cheap to fix.
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Done about 20k in my 2.2 dti, had it since about 50k. Only problems i've had with it are both boost hoses splitting within about a month of each other. No other problems and i'm lovin it. Certainly makes a change from my old peugeot 307's i've had, every one i've had has been back to the dealers for 1 problem or another. Most of them was before the car had even done a thousand miles
    Shropshire, England
    Hello All,
    Nice replies and good information. A forum worth belonging to!
    Modern cars are something of a worry, aren't they? I didn't realise that a DTI pump could be so much. I just thought it was the common rail thingies that were expensive....
    I'm starting to wonder if petrol engines are the way to go, despite the fuel cost, as I only do about 10,000 miles a year or less. This is assuming that problems on those wouldn't cost an arm and a leg as well.
    Thanks,
    on a low mileage like that then you'd not really save that much money..if you look in the troubleshooting section you'll see that petrols make up a small amount of queries compared to the diesels..As a rule petrols are cheaper to fix, but it's the economy that suffers..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you're looking for lowest cost, then you don't do anywhere near enough miles to warrant the extra cost of diesel. Unless the purchase price is less than the equivalent petrol, then forget it financially.
    My old DTi (Vec B) did 85,000 almost trouble free miles for me. Only thing engine related that happened was the injector return lines perished a little bit. I never did replace them though, as it was never a real problem for me, and then I sold the car and bought my current chariot.
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
