Thread: Wobbly bolts
    Tyneside
    Default Wobbly bolts
    Im thinking of getting a set of wheels that may require using wobbly bolts, just after a bit of feedback. Do they secure the wheels as good as normal bolts? Is there an increased risk when using them?
    Also the wheels are 9.5x20 with pcd 5x112 et35, can anyone confirm that these would fit or would I need 8.5x20?
    Any help is welcomed thenk you in advance.
    Mark
    the biggest ones irmscher offer is 8.5 x 20...and ET35, so thats a confirmed fit..
    5x110 is standard, but with wobblys you'll get away with 5x112...they will hold just fine..
    Tyneside
    Cheers Mark You are a the answer to all questions.
    Regular Member j1 wyx's Avatar
    Gosport-Hants
    they will be ok m8 we have them fitted to ours as the wheels are 112 fitment
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    I reckon you will be pushing your luck with front clearance with 9`s though, I would be concerned they will scrape on full lock, 8.5`s would be safer ...
    Tyneside
    Quote Originally Posted by Bainie View Post
    My thoughts aswell Bainie, at least they're a gauranteed fit and still gives a decent amount of rubber for the bends
  1. Wobbly Bolts
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2007, 22:10
  2. Wobbly bolts. Where??
    By freks in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2007, 06:40
  3. Wobbly Bolts
    Last Post: 1st February 2007, 22:32
  4. Wobbly Bolts for wrong PCD ???
    By Bainie in forum Suspension, Wheels & Brakes
    Last Post: 9th July 2005, 19:40
