Thread: can sombody please tell me how to
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Default can sombody please tell me how to
    get my rear sest to fasten back into its catches. i dropped it a couple of weeks ago and now i cant for the life of me get it fastened back properly, im probably being a bit thick here
    usually a good slam is enough..try the lock with a screwdriver to see if it works correctly..
    Regular Member simon5800's Avatar
    May 2007
    derbyshire
    is it the left hand side? i had a problem with mine and just had to give it some force, should go straight back to where it should be.
    Brighton
    Default Stiff Catches
    Mine did the same, I had to really thump it hard to push it back, I think they are stiff from lack of usage, (I hope that's the reason ) Either way, they open and close like they should, still very stiff to engage back into their catches......
    Hope this helps
    Steve
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    As mark says, mine usually needs a couple of good slams to lock back in place.
    Feb 2007
    Durham
    both sides, ive whacked them back quite firm but still wont fasten, will try screwdriver tomoz.
    May 2007
    Doing stuff
    Any Luck ?
    Make sure that the lock is still in the open state then a good slam. It is suprising how much of a slam you need .
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Mine are a bit stuburn too!
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I had this, took it to my local dealers, how silly did I feel when the fitter just gave them a real hard slam!
    Slam it harder than you think necessary, but not too hard.
    HTH
    Feb 2007
    Durham
    gave them a good hard slam and they are now sorted.
