Thread: Rear Window Crank
    Regular Member Damian's Avatar
    Market Drayton
    Default Rear Window Crank
    I am really struggling to remove the window crank from my rear doors. I suppose it doesn't help that I don't really know what the fastening clip looks like to release
    Can anyone offer some wise words, I have tried the old credit card method as previously suggested but I suppose I am just worried about causing too much damage
    it's a horseshoe shaped clip...and it can be a little swine to shift..laser and other companys do a little tool to just spring them off.. normally only a few pounds..
    Market Drayton
    Cool, do you have a web link for such a tool or should I ask in Halfords or B&Q perhaps ??
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Try putting a thin t towel in between the handle and door card. It might take a few attempts but if you pull the towel taught and pull it up and from side to side then the C shaped clip might and hopefully pop out. Not tried it on my Vec but it has worked on other cars for me.
    Inverurie
    If you have a really thin shaft on a screwdriver which is quite long and you no longer need (get a cheap one form the pound shop or something), bend the end about 15-20mm up to about 45 degrees from straight. This will then let you get at the ends of the circlip to push it off.
    Luckily for me I had such a screwdriver pre-bent from trying to lever something off a coupl eof years ago. Didn't throw it and found it useful for all sorts of things ever since
    Andy
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    as said use a cloth but put it between the crank and the plastic disc (behind the crank but in front of the door card) plus go from under the long part of the crank and press the door card back and move the cloth from side to side and the clip will come off no problem
    pics to show clip and handle
    not the best pics in the world but gives you an idea
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Great Pic beavis...I've wondering about this for a while. I've tried a couple of times without success. Cheers.
  1. Rear Window Blind
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2008, 19:58
  2. Help with rear quarter window
    By Itsallrover in forum Bodywork & Interior
    Last Post: 12th May 2008, 21:53
  3. Rear Electric window
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2008, 02:23
  4. Rear window winders...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2007, 20:03
