Thread: where is the EGR valve?2.2 petrol veccy.
    bradford, west yorkshire
    confused where is the EGR valve?2.2 petrol veccy.
    hi all.
    any one know where the EGR valve is located on 52 PLATE VECTRA SRI 2.2 PETROL?
    thanks all.
    essex
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    In the spirit of the forum here you go, got my spanner out and managed to trap my finger in the god dam butterfly! God it hurt!
    One throttle body showing the butterfly on the middle (brass disk).
    Now look into the TB and you can see a little pipe think sticking up into the airflow, now thats part of the valve your looking for. you can also see it from the underside of the TB and the track the plumbing takes.
    Now all you have to do is PM Mark (GSI 3.2) or benny and get them to fully explain the thing (as they have far more knowledge than me.)
    If you take a look at the link I gave you to the Z22SE.co.uk site in your last thread you will see that the guy has now taken out his EGR valve, blanked it off and fitted a little bit of electrical magic (made by Vocky) to fool the ECU that the valve is working fine. You may think this is bad but its what VX do to the Z22SE to sort any probs with it except they turn it off using tech 2.
    EDIT, ps the guy with the duff valve,s car is now running sweet as a nut. This is a common cheep mod to the Z22SE as it allows better airflow.HTH
    Vehicle : SRi
    Mileage : 137000
    And here is the link to that thread again.
    http://www.z22se.co.uk/forum/viewtopic.php?t=5846
    Vehicle : SRi
    Mileage : 137000
    Forgot to put this in. The silver brum/barrel shaped thing in the middle of the pic.
    This is the actual valve, and as I mentioned if you follow the path of the plumbing it will take you to the TB. So now you can see what you will need to remove to get rid of a dodgy valve. You could always just replace the valve but I would only replace with a new one and I dont know how much VX would charge you.
    Have you had it plugged in yet to see if it is actually the EGR that is at fault?. You never know but you could be barking up the wrong tree.
    as a quick post, a guide price to buy a new EGR is around £90+vat..and they're easy to swap at home yourself....
    a more detailed explanation when i'm back on here properly if you still need it.
  1. EGR Valve? 3.2 V6 Petrol
    By marcdale in forum Engine & Drivetrain
    Last Post: 27th May 2011, 10:23
  2. EGR Valve on the 2.2 Petrol?
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2010, 17:09
  3. 1.8 petrol 16 valve power increase,s ?
    By clancruiser in forum Petrol Engine related
    Last Post: 13th March 2010, 18:20
  4. Veccy C SRI 1.8 Petrol G/box leak
    By luap2411 in forum Engine & Drivetrain
    Last Post: 6th June 2009, 15:52
  5. veccy c cdti sri dump valve???
    By kojak01 in forum Diesel Engine related
    Last Post: 5th March 2009, 08:45
vectra c 2.2 sri egr valve location
where is the egr valve located on a vauxhall vectra 2.2 petrol
does vectra 2.2 2004 sri petrol have an egr valve
egr location on a 2.2 vectra
egr valve location vectra 2.2 petrol
egr valve vectra 2.2 petrol
vectra c 2.2 petrol egr valve 2004
is there a egr valve on a vectra 2.2 petrol
vauxhall vectra 2.2 petrol egr valve location
astra 2.2 sri engine egr photo
vauxhall vectra egr valve location
does my 2.2 vectra have an egr
egr valve vauxhall vectra 2.2 petrol
