Results 1 to 10 of 16
Thread: v6 vectra b whistling noise
    orkney
    Default v6 vectra b whistling noise
    hi, ive got a 1996 2.5 v6 vectra which whistles when accelerating , it sounds like an induction noise (it has a k+n filter) but its very high pitched and loud ,, any ideas..?
    Regular Member dazzer t's Avatar
    stoke on trent
    to be honest mate the best forum to go on is vvoc, there are loads on there with the 2.5 v6 veccy b, i'm sure they will sort you out.
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    My old veccy B V6 made a high pitch whistling noise just before the timing belt failed, well it was actually one of the tensioner pulleys that was shot. Cost me just over £1000 to sort. I'd get it diagnosed ASAP.
    Mileage : 000
    Might be one of the bearings in the tentioner pullys or the guide rollers breaking up, if it does fall apart the belt will come off and cause........... well loads of damage.
    Regular Member leeandjude's Avatar
    Feb 2007
    boldon, sunderland
    i think i know what the problem is but i cant remember what its called! its at the back of the engine....can anyone post a v6 engine piccy so i can point at it?
    had the same problem on mine years back...
    what, you thinking EGR link pipe???the steel convoluted one coming up by the cambelt drive cover?
    Feb 2007
    boldon, sunderland
    erm...all i can remember is its at the back and was held down by two allen bolts was sort of oval shaped about 6inches wide? (useless i know!)
    rear left right or centre?
    Feb 2007
    boldon, sunderland
    i think it was to the right (standing at the front). cant remember why but when i got this guy out to do a diagnosis check (via ecu) he put some 'gum' round it and the sound went away for a while
    orkney
    i took the filter off and the sound is coming from inside the induction pipe
  1. What is that whistling noise....
    By baldieone in forum Troubleshooting
    Last Post: 21st March 2011, 10:15
  2. whistling noise
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2010, 21:06
  3. whistling noise
    By fizler316 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2009, 16:22
  4. Whistling Noise When Revving
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 26th November 2008, 10:23
  5. squealing/whistling noise
    By cholly69 in forum Engine & Drivetrain
    Last Post: 30th August 2008, 08:29
vectra c whistling noise
vectra v6 induction whistle
