Results 1 to 10 of 11
Thread: Couple of queries - LPG and BSR stage1
    Mansfield, Nottinghamshire
    Default Couple of queries - LPG and BSR stage1
    Hi - I've recently purchased a 2.0T 2004 Sri Vectra and have a couple of queries if anybody out there can help me out.
    First off I'm looking to get it LPG converted and was wondering if anybody else had done this previously and how it went, what system they went for etc?
    Second is I want to look at getting the BSR stage 1 conversion - will this work ok with my lpg conversion? I'm presuming the BSR changes the engine management for the petrol ECU so to utilise the power I'd have to be running on petrol but will I have problems if I swap over to the LPG and it's ecu or will they be incompatible and I'll have to remove the stage1 to use it?
    Any help would be appreciated.
    Mark
    Here, there and every where!
    Phew! That's a good question m8. If you can get hold of Justin at BSR he will be able to tell you
    [Ex]Admin Duncan's Avatar
    As above, ring Justin at BSR UK (01932 338 600) and they can contact Sweden to find out. If you end up going for the BSR, don't forget to take advantage of our Group Buy.
    Sep 2009
    Slovenia
    masmit: sorry to bring this post from the dead, but I am just about to get Vecy 2.0t Estate (2007) and I am interested to install BSR stage1 with LPG conversion.
    Any new information on this combination?
    Thank you.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Hi mate
    I know they advise a higher octane but LPG already has a high octane rating higher than petrol anyway or so im led to believe.
    So you should not have a problem
    Sep 2009
    Slovenia
    Hi Sean, thank you for quick reply. You are saying I don't need to worry. That's perfect.
    Is anyone here with LPG conversion on 2.0t even without remaping?
    Apr 2008
    Liverpool
    Quote Originally Posted by buggy View Post
    As far as im aware mate the only problem I could see would be the octane rating and LPG has a higher octane rating than petrol.
    but as advised above still give the guys a ring to double check but I cant see you having a problem mate
    Full Member Big Sig's Avatar
    Give BSR a ring and ask
    Sep 2009
    Slovenia
    I will send them mail with that question, but I just checking here if someone has any new input on that case from practical point of view. So no LPG 2.0t owners here with BSR (or without).
    Thank you all.
    BTW: I found this forum very useful with tons of information. I hope my purchase with Vecy will go well, because reading posts here about 2.0t engine makes me want it even more.
    Sep 2009
    Slovenia
    Got information that this (minor) remapping will have no inpact on LPG conversion (before or after).
    If some problems after remap will for some reason occurs, this can be sorted with small pressure modification. LPG electronic just get signals from main ECU and adept them for LPG run.
    Now just need to wait for the car
    P.S: this is the firm which will do conversion http://www.g-1.si/index.php?option=c...tpage&Itemid=1
  1. Few Queries
    By Adam B in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2010, 01:27
  2. Spotted a couple in Dundee the past couple of days
    By John LE in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 2nd March 2010, 23:49
  3. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
  4. BSR stage1 - 2.0 turbo
    By Mrsan in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2008, 18:33
  5. Newbie - couple of queries
    By masmit in forum Suspension, Wheels & Brakes
    Last Post: 4th August 2007, 13:45
opel vectra c 2.2 direct installation lpg
