Will this fit my 1.9CDTI (120)?
Should do!
I'm sure you already know but just in case ... assuming it's the whole system/rear it will be dual exit so you may need to modify/change your rear skirt if yours isn't already? ... and depending on the model it came off the ends may point down to hide behind the skirt (they do on my elite )
Dave
steve
if its off an sri 3.0 like you say it is then it will have the sports chrome
oval tailpipes,its only the basic models or the elite that has the hidden
tailboxes.
most of the centre sections are the same diameter so all you will need is
the rear tailbox setup and obviously you will need the rigth exit open for
you to fit the right tailbox
