Thread: Scraping Brakes?
    Stafford
    confused Scraping Brakes?
    Had all new pads and discs fitted about six weeks ago at a dealer. Shortly afterwards noticed a scraping sounds which put down to a bit grit getting caught between the pads and discs.Hasn't cleared but is very intermittant and generally only appears if I do a sweeping right manouvre at slower speeds such as an roundabout or sharp right hand bend. Noise seems to come from front passenger wheel.Been in to dealers today and they couldn't find anythings. They have re-positioned rear brakes but on way home got noise again.Any ideas?
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Gsi3.2 is your man for the definitive answer, but just sounds like rubbing pads to me. need to get a bit of copper grease in there (not on the disc!)
    to stop them squeaking.
    Stafford
    Doesn't sound like a squeak or squeal though. Sounds more like a grind.
    Feb 2007
    Quote Originally Posted by BUTCHERS View Post
    ???? Send Gsi3.2 a message, he'll give you a few ideas what it might be, he's the nuts and bolts guy on here!!
    front brakes...???..
    if it's the fronts then i wonder about the disc sheilds touching.. other than that, have they fitted the springs back correctly?..they hold the calipers in line..
    Feb 2007
    See... here he is!!
    the definative answer will only come thou when the brakes get inspected..
    Quote Originally Posted by sonicboom View Post
    See... here he is!!
    he's everywhere....
    Stafford
    Thanks guys, I'll take a look at this tomorrow. It's due in again on Tuesday so I'll mention that to them.
    Stafford
    Problems has dissapeared since last week. Maybe their was something caught or on too tight. Been ok for a week, have to see how it goes.
  1. ABS light and scraping
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2012, 20:55
  2. Fed Up Of Scraping the Splitter
    By delete2 in forum Handling & Braking
    Last Post: 22nd November 2010, 13:55
  3. scraping noise with brakes
    By dodus in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2009, 20:41
  4. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
  5. scraping noise
    By dave t in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2008, 10:32
