Results 1 to 10 of 17
Thread: Radio display bulbs?
    north
    Default Radio display bulbs?
    hi there,
    i am new to the site and have been searching for hours to find out if the bulbs on the radio display on my 03 vectra can be changed as one side of the diplay is very dull.
    i can only find how to change the full display etc .
    any help appreciated.
    Joec
    They aren't bulbs - they are SMDs (surface mount diodes) so not really replaceable (well you can but it's tricky). They should rarely blow as they are such low current so maybe due to something else?
    To know for sure, you could always pop the display out and see if all the diodes are lit up and if there is possibly a loose connection to the display? I'm not sure if that's possible with the type of connector (having a loose connection), I'm not sure.
    north
    thanks for the quick reply duncan.
    this is what i get
    is it possible to see what diodes are lit by just removing the unit or do i need to remove the rear cover?
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    for the price they go on ebay i would get one off there
    as for changing it only a 5 min job
    Baz
    I'd expect you'd need to remove the rear cover to see the diodes. Somebody's had theirs apart on here - just trying to recall who it was. Think they even did a How 2. One sec......
    Here we go. It's not clear as to whether you can see the diodes separately from the display, but maybe just worth whipping out the display to make sure the connector is seated fully home. If it is, then as above probably easier to just get one off ebay and replace it.
    north
    problem sorted .
    i took out the display and there are 3 small bulbs along the back .
    2 where duds.
    my display has a different back to the one in the link in the previous post but on the picture of the cicuit board you can see the 3 holes where the bulbs sit.
    thanks folks just need to source new bulbs 12v 2w
    Result!!
    You learn something new every day! I thought all the Vectra C displays had no bulbs behind, just all SMDs. Obviously not on the two line display! Although thinking about it, it's probably the same screen that was in the B, hence it not being SMDs.
    Anyway, at least you found the problem and it's easily fixed.
    Regular Member korlinski's Avatar
    South
    what would happen if different coloured bulbs were used?
    what would the effect on the screen be?
    Err, it'd change colour?
    The normal bulbs are white, the display is orange so you'd end up with whatever the mix of a different colour bulb and the display colour gave you. Before you ask exactly what the colour would be, no idea - one to try and see.
  1. Radio display
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 18:18
  2. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
  3. radio display
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 22:09
  4. Radio off display
    By n33712 in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2008, 15:54
  5. Radio Display
    By mjhayward in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2007, 10:13
