Thread: Engine oil & VX dealers
    Mar 2007
    OXFORDSHIRE
    Default Engine oil & VX dealers
    Question: Is it acceptable for a Vectra CDTI 120 HATCH 2004 to use semi 10w 40 as installed by by local main dealer during recent service. They say it is but i can't see semi 10w 40 on the VX approved list.
    Is the dealer trying to encourage me to return every 10k rather than 20k for LL fully synthetic?
    Notice the car gives a puff of blue smoke on cold start (clears immediately and no obvious oil use) where as when the car had fully synthetic it didn't.
    Advice appreciated.
    they shold have used the 5w30 oil, as it's what is needed for the longer drain intervals and provides superoir engine protection .. they used the 10W40 for one reason onlyy.. ITS CHEAP and they can make more money on it.. If your car is an auto then they MUST use 5w30 no matter what the drain interval.. but to say that using the 10w40 is okay isn't really correct..
    Regular Member wardy's Avatar
    Chichester
    I had same problem. I returned the car, had it flushed and 5w30 fully synthetic put in free OC.
    Mar 2007
    OXFORDSHIRE
    Default Thanks
    Thanks for the info. I'll let u know the outcome of my chat with the dealer.
    Mar 2007
    OXFORDSHIRE
    Default Update
    Local friendly main dealer sheepishly acknowledged error and replaced with fully synthetic LL oil plus filter FOC.
    nice resulto..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Amateurs.
    How many more have they done that to, and no one questioned it???
    Mar 2007
    OXFORDSHIRE
    Default There's more....
    The best bit is (apart from using the wrong oil) that during the original service they urged me to replace the rear brake pads because they were 85% worn (£80 to you sir!). Had a look myself and got a local garage to offer an opinion.....the result being that the rear pads are less than 50% worn!! So, do you think i'll be using local Vx dealer again?
    Regular Member CDTi Mike's Avatar
    Dec 2005
    Melksham, Wiltshire
    Quote Originally Posted by billythechid View Post
    Yep, exactly the same for me!
    Not surprising though since it was a free service due to a balls up during the original sale.
  1. New key at the dealers.......
    By peelmeister in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 08:20
  2. dealers
    By jason1 in forum General Chat
    Last Post: 26th August 2009, 21:37
  3. What Will Dealers Think Of Next???
    By Ben H in forum General Chat
    Last Post: 20th October 2007, 07:05
  4. In at the dealers
    By blr123 in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2006, 21:40
  5. down at the dealers
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2006, 15:02
