Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Error Code P0715
    Jun 2007
    Calne, Wiltshire, UK
    Default Error Code P0715
    I know the definition of this code....
    .. and what it can mean.
    But, I've no coolant loss, and the Gearbox oil is a brown colour, not pink.
    It's smells burnt and smelly. What the hell is going on?
    Do you think it's worth a gearbox oil change, and if so, how much ATF does the Auto Gearbox take?
    Slightly more importantly, where are the Drain, fill, and Level plugs on the box?
    Cheers.
    Matt
    right, brown and smelling burnt is the fluid telling you the internal brake bands ( clutch plates) are shot..the only real cure is replacement of those components or the entire box ( i have a workshop manual for it if it's needed which i can email)..changing the fluid will mask the problem, but you'll still have a sick gearbox..it really needs some serious work done....if however it's just a really deep red then a change of fluid will normally help.. but if it's giving an error code then my money is on the bands..
    drain plug is on the bottom on it's edge along the bellhousing seam it's a big (19mm) bolt.. undo and drain fluid into a poundland washing up bowl....measure how much came out with a poundland kitchen measuring jug..the filler bolt is on top..and the level dipstick is the small green stalk secured with a 13mm bolt of the front of the dipstick...
    I'm going to PM you for your email addy to send you some relevant files.showing their location..
    PM replied to and files sent..
    Jun 2007
    Thanks Mark,
    Yep, there is definatly no red in there... just good ol' brown.
    think is, the light came on a while ago and I've been limping around in it for a week or so now... (had no other choice sadly, as I was 300Miles from home!)
    It trys to pull away in 5th from a standing start... could that have something to do with the "browness" of the oil?
    I thought maybe I've burnt something trying to pull away in fifth would have ballsed the oil up... but like you say it could just fix it for a bit.
    I Assume this speed sensor turbine wotsit is actually inside the G/Box?
    Thanks for sending those Details.
    Cheers.
    Matt
    Regular Member sophos9's Avatar
    Norfolk
    There is a field remedy E0001650 for that error code but no exactly the symptoms you are indicating...
    AF23/33 transmission - No driving torque because of cooling water in transmission oil
    Models: Engines: Option:
    Vectra-C 2002...2004,Signum 2003...2004 Z22SE| Z32SE| Y22DTR,Z22YH| Z32SE| Y22DTR AF23/33 Transmission
    Complaint: Loss of the transmission functionality in isolated cases. The following symptoms may occur occasionally: - failure codes P0700, P0715 or P0720 set - slight loss of cooling water - sediments in coolant expansion tank
    Cause: Improper function of the sealring at the oil cooler conncetion. This can cause the penetration of a little quantity of cooling fluid into transmission oil.
    Production: An improved oil cooler/radiator has been introduced in production as of VIN W0L0ZCF3541042598 (Rüsselsheim) and VIN W0L0ZCF6848035197 (Ellesmereport).
    Remedy:
    In case of customer complaint proceed as follows:
    If only DTC P0700, P0715 or P0720 is stored please carry out TSB 1685.
    Open the black cover of the valve body on the transmission housing carefully. If water and/or white sediments are found in the cover the transmission has to be replaced together with the oil cooler/radiator assembly.
    You did say you have no coolant loss though, Hmmmm.... I believe the sensor is in the box, do you have warranty?
    First thing I would do is change that oil and see if that improves the situation, as GSI said tho, this is a plaster...
    Jun 2007
    Yeah I've had those word spinning around my head all day.... ( Is that the ONLY reason the 0715 shows up..... admitadly my VIN is in that range... ;o(
    Cheers.
    Matt
    Norfolk
    Quote Originally Posted by Vectra-SRI View Post
    Hi Matt, unfortunately that's not the only reason you could get a 0715. Do you have warranty?
    Get that oil changed, reset fault and road test...
    Jun 2007
    Hello,
    No only the 3 Month standard one. Thankfully I've only had the car one month.
    So I'm trying to get them to take it back.
    I'll be doing the Oil this weekend.
    Cheers.
    Matt
    Norfolk
    Do that mate, could turn out to cost a few quid if a garage has got to sort it!
    What exactly are the road test symptoms?
    Jun 2007
    Spanner Light, Limp Mode, and Emissions light. Now this Error on the Code reader.
    Engine starts and Idles fine, but a few seconds (15 maybe) the spanner light comes on. Emissions light does not go out.
    Engine Temp, if fine, but Fuel Ec is down slightly, but I guess that is the Limp "wrist" mode.
    Idles, afine and the Engine as it is, is fine.
    It revs to the redline when in "N".
    Cheers.
    Matt
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. error code
    By frag45 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th December 2010, 14:39
  3. error code
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2010, 21:43
  4. Error code help
    By Cat_J in forum Vectra C / Signum Troubleshooting
    Last Post: 18th January 2010, 17:48
Vauxhall P0715
p0715 opel vectra
0715 vauxhall error code
p0715 vauxhall signum
vectra c p0715
p0715 vauxhall vectra
af23 zafira 3rd
dtc opel vectra
cod p0715 opel vectra c
p0715
p0715 vectra
Opel DTC P0715-00
p0715 vauxhall zafira transmission fault help
Opel DTC P0715-29
vauxhall p0715 code
opel vectra 2002 dtc p0715-0 solution
vauxhall code po715-29
Opel P0715
p0715-00 vectra wiring
p0715opel
Vauxhall DTC P0715-29
