Results 1 to 10 of 11
Thread: Jigsaw (the electric ones)
    Regular Member MLC's Avatar
    uk
    Default Jigsaw (the electric ones)
    I've been laying a wooden floor over the last couple of days. Just what is the secret to cutting a straight line with an electric jigsaw. Can't do it to save my life. A drunken man would've done a better job
    Resorted to a good 'ole fashioned hand saw...nice and straight
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Nice and slow with your other hand guiding the bottom plate.
    Or buy/borrow/hire a sliding chop saw with a fine tooth blade like we did!
    Is it a real wood or engineered?
    the trick is to leave the jigsaw in the shed and use the circular saw instead.. horrid things those jigsaws, for cutting curves only.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    always used a mitre saw for mine mate
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Jigsaw's are only good for corner's, other than that, a normal hand held saw will be far better!!
    Regular Member m20_swe's Avatar
    Oct 2006
    greenock
    same as the rest of the guys said leave it in the shed lol you really need a rip snotter or a hand saw mate will be the best way or if you have a hand plane leave a few mm on with the jig and plane the rest
    Clamp a straight piece of wood across the board you are cutting and use it like a 'fence' to run the jigsaw along.......
    ..... I knew those hours of watching Discover Home and Leisure would pay off one day!!!!
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    you need the blades that cut from underneath,that way you can clearly see the line you are attempting to follow...............being a bedroom fitter we have to cut the top fillets on site,mind you it does take a lot of practice to cut 2 meter lengths without running off the line,so tiny bits of flooring is no problem....also the advantage of doing it by jigsaw is the fact the
    cut might not need to be square square.
    Feb 2007
    North west
    plenty of practice and straight cuts are no problem, get a decent jigsaw 500 watts + and pendulum action. You can get blades sharpened for cutting on the downstroke / std upstroke or both. Laminate flooring all your cuts will be out of sight anyway.
    Regular Member lborob17's Avatar
    Rainy Derbyshire
    take the skirting off - lay the floor - put skirting back - that way:
    a) dont see the ends (which are probably easier to cut with a hand saw anyhow)
    b) you don't have to resort to using those nasty skirting to floor fake wood trim strips
    I only use jig saw for things like the hole in the work top for the hob etc - Circular saw for everything else, or if I want accuracy - do it by hand!!. I think the knack to succesful jig sawing is
    a) make sure you have a sharp blade
    b) make sure the blade is set up correctly and not too much slack all ways
    c) let the saw do the work (I hear my Dad's voice saying this as I type!) - ie never push and force the saw along - just let it go at its own pace.
    d) don't use a guide - just use your eye (behind PPE!!)
  1. When are electric blue bulbs not electric blue?
    By krisby in forum General Motoring Chat
    Last Post: 29th November 2011, 13:20
  2. Final Peice of the ICE Jigsaw!
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 31st March 2011, 22:22
  3. WOW I now have electric
    By garvey in forum General Chat
    Last Post: 4th February 2009, 13:43
  4. Electric Fan
    By mr.4dil in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2008, 19:54
  5. Jigsaw of your motor!
    By VectraMat in forum Comedy & Humour
    Last Post: 19th June 2006, 21:09
