Thread: Help With error CODES...!!??
    Leeds
    Exclamation Help With error CODES...!!??
    Hi a im am a new member/owner, driving along and my dreaded spanner with a car sign came on...loss of power max 30-50MPH, fine this morning but took the car to a local garage had it checked on snap on computer gave some error reading, any help would be much appreciated.
    1.P1590-Vacuum solenoid valve circuit (high voltage).
    2.P0234-Boost pressure control (negative deviation).
    3.P0380-Glow device circuit (low voltage)
    Thanks people
    I assume you've checked the old favorite on the DTi??..the boost hoses split and give the same symptoms as you describe..they are worth a very careful look over first.. look at all of them
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Is there more smoke coming out of the exhaust than usual??? When both of my boost hoses blew (2 different occasions) it was kickin out a load of smoke.
    If it is take the top plastic cover off the engine and check both left and right hoses. Both of mine split underneath so you have to feel for any splits.
    Leeds
    Default help
    Thanks to you i will get it checked today, please all feel free to give me your views, all help much needed!
    i thought i got away from these little manufacturing teadous fault code, had a VW Golf too many little probs, guess there's no escaping the trouble some .
    Oct 2006
    coventry
    Quote Originally Posted by sheiky View Post
    tried replying to your PM m8 but your inbox is full. Heres what i was gonna send.
    If i remember correctly the hose on the left is about £100 and the one on the right is about £70. The reason they're so expensive is because you cant just buy the rubber hose, it comes with other bits. Has your hoses actually split?
    Check them before you go and buy a hose as it might not be.
  1. (error codes)
    By tomo610 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2012, 20:07
  2. error codes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2012, 20:33
  3. 3.2 error codes help please
    By gibsonk in forum Engine & Drivetrain
    Last Post: 28th January 2012, 13:03
  4. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  5. error codes
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 13:27
