Results 1 to 10 of 15
Thread: Car Wet Inside
    Regular Member evsy72's Avatar
    south wales
    confused Car Wet Inside
    Need a bit of help. After all the rain we've had noticed the floor behind the drivers seat is very wet and before you say it yes all the windows were shut. Cant find where its coming from has anyone else had this and how'd you cure it..
    Jul 2006
    Mexico
    may be the door seal.....or the window seal.....give them a check check also your boot where the spear wheel is at...just to see everting in orther back there
    Nicking Ya Dinner.
    Window seal will be favorite, have a look under the rear shelf to see if it's coming from the quarter light.
    bolton
    Thumbs up
    Had the same put in front passenger well checked for where it was coming from but no joy. Put it down to the Mrs not closing the door completely and leaving a gap for the rain to get in!!! Will keep an eye on it though
    get the hosepipe out.... run it over the car while you have someone inside to see where it's coming in..
    harborne birmingham
    edz1086 if you have water in the front passenger well check that the drainage hole by the air con filter is not blocked,ive had this with my car
    Regular Member tash's Avatar
    grimsby
    the rain is only coming in to keep dry,,had this with mine car,,still aint found were its coming from,,only does it if car parked on the roadside were the camber is,,not on my driveway
    Jun 2007
    leeds
    did anyone sort this problem out has im having the same
    the car just sat on my drive and when it rains the passenger footwell fills up with water been told it could be seals gone on the front windscreen
    at £60 to replace the seal or if there crack the glass getting it out £132
    to replace , its gunna be expensive if its not the seal thats gone
    any help guys
    thanx in advance
    Leicester
    I had the same on my 06 reg car.
    The following should help.
    1) Lift the bonnet
    2) Remove the windcreen wiper arms and the plastic scuttle panel, this should take only a few minutes.
    3) On both sides of the car on the flat part of the bulkhead beneath the plastic scuttle, there are two drainage holes that go down behind the engine onto the floor.
    4) Check these are not blocked with leaves or other rubbish, simply push your fingers through and if they are blocked, simply push it through to the floor.
    What tends to happen if these are blocked, water will build up on the bulkhead and leak into the car through the pollen filter. It then goes doen the carpet and tends to settle on the floor at the back of the front seats.
    It may not solve your problem, but it is worth checking.
    Regular Member shan's Avatar
    I was told to keep a check on the air filter area above the passenger footwell. Access from under the bonnet. This area can gather leaf's and other cra p infront of the filter and then the water will not drain away and get's into the footwell.
    About the rear i'd check the door seal's.
    Happy hunting
  1. wet inside
    By chrisg in forum Bodywork & Interior
    Last Post: 7th January 2011, 23:51
  2. I have to de-ice the inside!
    By willywoofter in forum Troubleshooting
    Last Post: 17th December 2010, 12:42
  3. Inside
    By savage. in forum Styling
    Last Post: 15th June 2009, 00:17
  4. New look inside
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2006, 18:41
