Results 1 to 10 of 13
Thread: Random Corsa C "Not Starting"
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    Default Random Corsa C "Not Starting"
    I wonder if any of you guys have any ideas on this problem that we are having with my sister in law's Corsa C?
    Its a really strange one, Sometimes for no reason at all it will just not start. totally dead. if you jump start if it works fine, and then its fine each and every time after that.
    When this happens its few and far between, but when it does it is a huge pain in the bum. What could it be?
    Please help
    Thank you
    Cirencester
    Possible Faulty CIM?
    Nicking Ya Dinner.
    Does it crank over and not start? or is it a nothing at all scenario?
    Bad Earth
    Draining Overnight - Boot light is a fav for this.
    Dead Cell in battery
    Alternator
    May 2007
    Doing stuff
    could be a crankshaft sensor they also cause intermitent starting probs, no fault codes, good luck
    Devon
    Engine : 2.0 Turbo
    ok thanks for your help so far....I've got some more information on the fault....
    1. It clicks and clicks but makes no attempt to turn over
    2. it will happen even if the car has been run. e.g on a trip into town, stop the car, try and restart but it will not. intermittent again, no warning
    Cirencester
    in that case, a faulty starter motor. the clicking will be the solineod.
    Devon
    Engine : 2.0 Turbo
    Thanks jonr, does that still hold true if it then starts fine when being jump started?
    Cirencester
    does the car ever turn over with the key or does it need bump starting?
    Devon
    Engine : 2.0 Turbo
    we haven't tried bump starting it. once on the jump pack it starts with the key as normal
    Cirencester
    oh ok. battery then. replacement battery of a know good subsitute is the only way mate
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. random question - 17" to 19" wheels
    By rob1981 in forum Handling & Braking
    Last Post: 26th April 2012, 12:23
  3. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  4. Corsa 1.4i Sport. 2000 "W" reg
    By RhayaderSax in forum Cars for sale
    Last Post: 12th April 2009, 17:21
  5. '95 "M" reg corsa 1.5 Diesel Merit
    By bruceybonus in forum Cars for sale
    Last Post: 18th May 2006, 00:41
