Thread: Help 150CDTI - Power problem
    Oct 2006
    Yorkshire
    Default Help 150CDTI - Power problem
    All
    Please help me understand what has gone wrong here.
    Car is an 04 plate SRI CDTI 150bhp with 46k on the clock.
    Travelling home tonight, plenty of overtaking when started to hear a tick-tick-tick sound from the engine - just as I was overtaking a car. It's the kind of noise that I would have recognised from a car that had blown the exhaust near the manifold. As I registered the ticking sound, the car lost loads of power and I had to pull back in.
    Pulled over and lifted the bonnet, no apparent problems as all except that the car has very reduced power - the turbo is not spinning as there is no whistle etc.
    Lifting the bonnet when home, got my dad to rev the engine whilst I looked under the car and in the engine bay and there seems to be exhaust fumes coming from the area indicated from the green line shown below on the pic. There is also what looks like a pipe with a metal sheething around it that is vibrating in tempo with the engine revs.
    Any ideas of what has happened?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    egr pipe that goes to the erg cooler may have come loose ....it is in that area and looks like a coragated pipe ..
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Just nipped out to the car and had a looksie.
    The clamp that holds the hose on is one of those, ready to fail clip on clamps.
    If that is loose, then put a worm drive hose clamp on it. That should sort it.
    Hope this helps
    Oct 2006
    Yorkshire
    Default help
    Thanks Chaps.
    Would this thing coming loose stop the turbo spinning?
    Oct 2006
    Yorkshire
    Default pipe
    Quote Originally Posted by benny View Post
    bang on, dealer told me today that the pipe had corroded and broken off ...so no backpressure for the turbo.
    £196 to fix it and should be back tomorrow.
    Was surprised that it has worn so quicky at 46k miles???
    On another planet
    Engine : 2.0
    Quote Originally Posted by bennyk View Post
    Isn't it fixable under warantee? Assuming last reg 54 plate
    Oct 2006
    Yorkshire
    Default pipe
    ...got the car back today, feels much pokier than it was before.
    100 yards out of the dealers and tuning box back on weeeeeeeeeeeeee!!
    morton
    ooo you little raskel !!! he he
  1. Help!!! Injector seal problem 150cdti
    By scrumpus in forum Engine & Drivetrain
    Last Post: 18th November 2011, 20:03
  2. power to radio problem
    By MARKPRIOR in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2011, 13:33
  3. 150CDTI - Intermittent total power loss
    By birdii in forum Engine & Drivetrain
    Last Post: 18th April 2011, 22:16
  4. which is faster top end,150cdti facelift or 150cdti pre facelift?
    By andy d in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2007, 00:43
  5. Power Steering problem
    By H11LGX in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2006, 01:19
