Results 1 to 10 of 11
Thread: Where is OBDII (on-board-diagnostics) slot?
    Latvia
    Default Where is OBDII (on-board-diagnostics) slot?
    Good afternoon,
    Where is OBDII (on-board-diagnostics) slot located? I am from continental Europe, accordingly my Vectra is right-hand drive, if that matters.
    Previously I drove Astra G, it had its OBDII slot right under the hand-brake lever, but it does not seem to be the case with Vectra C.
    Regards,
    Karlis Brils,
    Vectra GTS V6 3.2.
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    The plug in diagnostic port is located under the ashtry but it is not OBDII as the preface lift is half canbus and the facelift is full canbus. I think the older OBD units don't work, unless some else knows different.
    May 2006
    scotland
    My CDTi is prefacelift (Jan 2005) but I have been advised because the steering has thumbnail scrolls and not 6 buttons, its a full canbus.
    Latvia
    Thank you for the hint, I'll look under the ashtray.
    Karlis
    Quote Originally Posted by wickedwillie View Post
    Your'e quite right, I was just using that as a general rule of thumb. Either way OBD doesn't work.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by willc01 View Post
    The thing under the ashtray is an OBD2 slot or DLC.
    Don't think that the CanBus has something to do about it (except that it is the way to acces it); you're probably referring to the fact that the enhanced code is GM/vehicle-specific so that you need Tech2 an not an ordinary OBD-reader...
    (By the way OBD was an innovation of GM and later on the USA obliged all manyfacturers who wanted to sell cars on the American market to have an OBD what became the OBD II-standard)
    Sweden
    Quote Originally Posted by sig63 View Post
    Yeah ... Canbus is one of several protocols used with OBDII.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    CAN bus is not a protocol, it is the infrastructure.
    SAE J1939 is an example of a protocol
    Sweden
    ISO 15765 would have been a better example as its the CAN protocol
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is that the CAN protocol that VX use?
    I couldn't think of a ISO CAN protocol, at the time.
    CAN = Controller Area Network, so cannot be a protocol in it's own right.
  1. CD70 will not load cd's in to the slot.
    By Jekyll & Hyde in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2013, 21:34
  2. OBDII iphone app
    By John Bishop in forum General Motoring Chat
    Last Post: 7th July 2012, 09:29
  3. Is the cd70 pcb circuit board coded as in a need a new board
    By gurjsagoo in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 00:07
  4. DIN Slot / Cup holders
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2007, 18:12
  5. Slot-In GPS System
    By greeningr in forum General Chat
    Last Post: 11th January 2007, 14:21
obdi slot vauxhall meriva 2011
