Thread: Rear Wash Wiper Sprayer
    Regular Member David_SRi_2.2DTi's Avatar
    Jun 2007
    Leeds
    Question Rear Wash Wiper Sprayer
    ...I've had the vectra since friday, and for the first time this morning had opportunity to use the rear wash wiper, but it seems the sprayer isn't working, I can hear the noise of the motor but no water emerges!
    Is it filled from a different reservoir to the front, as these are working ok?
    Regular Member Ben H's Avatar
    Herts\Beds Border
    No it does work from the same one as the fronts.
    Have you checked for leaks any where along the pipes route. Our works van pipe used to pop off like a nipple in the rear door shut and it would pour out on the floor.
    Mind you, don't get excited over it working. I have been meanng to post if everyone thinks the wiper arm starts to move far too early as when you spray, the water only gets one third of the way down the screen before it gets wiped everywhere thus leaving the area you realy need washing still filthy!
    Oh and spraying whilst going at speed is pointless.
    Regular Member stickshift's Avatar
    North London
    It's quite common for the pumps to get clogged. Pull the pump off the reservoir and clean the strainer in warm soapy water it should fix it.
    Jun 2007
    Leeds
    Quote Originally Posted by stickshift View Post
    I might investigate that! ...the front ones work though, that said its still in warranty with the stealership.
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Quote Originally Posted by Ben H View Post
    ...... I have been meanng to post if everyone thinks the wiper arm starts to move far too early as when you spray, the water only gets one third of the way down the screen before it gets wiped everywhere thus leaving the area you realy need washing still filthy!
    i know what your saying m8. Mines the same. I've given up using mine. Like you said the wiper starts too early and then wipes too fast (No intervals between wipes) so you only ever get the top bit clean.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    If mine's anything to go by it's a pretty pathetic trickle too
    Jun 2007
    Leeds
    Quote Originally Posted by Ian S100 View Post
    ...don't know which service baffoon did mine before I picked it up, but the passenger side sprayer at the front seems set to soak random pedestrians!
  1. Wiper blades and screen wash pump problems
    By lee1980 in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2010, 14:50
  2. rear washer sprayer
    Last Post: 14th October 2009, 09:56
  3. Rear Sprayer not working...
    By David_SRi_2.2DTi in forum Troubleshooting
    Last Post: 6th August 2007, 22:27
  4. Aerial and rear window sprayer
    By Johnytuono in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2006, 05:12
how to clean vectra c rear sprayer
