Thread: LED sidelight bulbs
    Leamington Spa
    Default LED sidelight bulbs
    fitted some of these to my dads 05 SRI CDTI estate and now there is a parking light error on the dash and a bulb on the screen in the rev counter!!
    both seem to work, are they just not compatible with the Veccy c?
    ta
    Hertfordshire
    Nope, the Vec C has a bulb failure warning system that constantly checks for bulb failures when ever the ignition is on, regardless of weather the bulb in question is in use or not.
    The system looks for a specific resistance, and compared to a normal bulb, led's will be far lower drain and will constantly trigger the system, hence the warnings on your dash.
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    You need to fit a resistor. Have a look on vvoc 's forum - thats where I got mine. Just site the resistors well away from anything plastic - they get very hot. (I've mullered the back of my lights!!)
    Leamington Spa
    cheers mate, any ideas though?:
    I have fitted them inline on the red wire to each sidelight but still have the error coming up on the display of my dads Vectra C, there is red and brown wire, am I doing something wrong?
    cheers
    Hertfordshire
    Yeah, the resistor would need to go across the wires to have any effect, not inline.
    Ie, one side to the red and one to brown.
    This will put a load on the resistor and it will quite possibly get very hot, so make sure it is up to the job.
    Not a solution I would personally like to use, but each to there own.
    Regular Member Robward27's Avatar
    Witham
    Got led's on mine with same prob does look good when u lock car because it sends a detection current round the bulbs and the led's flash a while after and before you set your alarm. lol
    Leamington Spa
    Have you got resistors fitted?
    or do you have the parking light error up oon the screen?
    cheers.
    Is there another solution?
  1. M -Tec 501 Sidelight Bulbs
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2012, 20:50
  2. Sidelight Bulbs
    By Tam80 in forum General Motoring Chat
    Last Post: 26th May 2012, 21:51
  3. LED sidelight bulbs/What do you use?
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2012, 19:39
  4. 501 sidelight bulbs
    By VectraElite 2.2DTi in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2010, 23:21
  5. M-tec 501 sidelight bulbs x2
    By bobby-tupper in forum Parts for sale
    Last Post: 31st May 2010, 14:24
