Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: My Tyres have shot it !!! BIG style
    Default My Tyres have shot it !!! BIG style
    Ive been experiencing a lot of noise for a while now and have spent a lot of money trying to quiet it down a bit ...... £500 on 4 wheel bearings being the most expensive by far .... which i must add has done the trick ..OR SO I THOUGHT !!! Just got back from my hols ... the journey was the most annoying time we've had , with the constant drowning and a noise i can only describe as WHEEL BEARING noise Talked to my mate marky about several things it could be, and when i got back went round to payneys and tried his SRI 17's on ...... the noise was gone ... checked the rear tyres and found to my horror that the inside edge hadn't just worn ..... it'd worn unevenly !!!! just like they had 2 or 3 flat spots each tyre , you can see the ripple effect around the tyre plain as day .. .... ALL i can think of is that its something to do with the rear neg camber on the gsi .... put them both on the front and you can tell they're toast through the steering ...... but they're better on the front because there a little quieter due to no neg camber , !! looking for a new set now as the other 2 are close to the limit as well !!!!
    has anyone else had this problem ... the tyres are the SEMPERIT PRO 235/35-19
    cheers
    phil
    Quote Originally Posted by big phil View Post
    checked the rear tyres and found to my horror that the inside edge hadn't just worn ..... it'd worn unevenly !!!! just like they had 2 or 3 little flat spots each ....
    Could you take photos of these?
    If the inside edge of the tyre has definitive patches of uneven wear, this suggests the rear suspension is at fault, either the dampers and/or shock absorbers have failed
    thats what mark said too .... i need to give the dampers a little test ..... i'll take pics tomorrow
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Quote "the tyres are the SEMPERIT PRO 235/35-19 "
    On what size alloys? (width that is)
    Belfast
    I doubt it's rear camber. More likely toe, or as you say knackered dampers or bushes.
    My Astra has nearly 10 degrees rear camber due to the lowering, and it doesn't wear the rear tyres at all.
    Or just **** tyres. Semperit? Thought they made inflatable boats?
    If you don't have access to a ramp or jacks, you can actually prove faulty rear suspension if someone is prepared to follow you while you drive...
    Get them to drive right behind you, ideally on a dual carriageway
    Get them to watch one rear wheel at a time by sitting directly offset behind you, although this does mean once they have observed one side you will then need to change lanes so that they have clear view of the other side
    What they are looking for is the wheel "bouncing" and losing continuity with the road surface
    When you've seen it once, you know exactly what you are looking for!
    cheers buddy !!! ZS semperit are the budget range from continental
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    blooooooody hell m8 hope you get it all sorted out......
    Midlands Mod Shop - NFFC.
    Ashington, Northumberland
    Just a note to all reading this thread. DAMPERS and SHOCK ABSORBERS are one and the same thing.....
    Just what i was thinking Gary....
    Phil knows which direction to be looking in....i think he's more worried if it's a problem with this brand of tyre..
  1. I'll get shot down for this!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2010, 21:30
  2. HDR shot
    By KevinG in forum Quick Photo Album
    Last Post: 22nd November 2008, 21:13
