Thread: Power steering noise
    Planet Earth
    Vehicle : Vauxhall Vectra C
    Trim : Exclusive
    Engine : 1.8i vvt
    Mileage : 37,500
    Unhappy Power steering noise
    Hello everybody not sure if im in the right place or not.
    I have a vectra 2.2 cdx 2000(not sure if its a,b or c model) and have a problem with the power steering,just behind the fluid bottle there is a pump i beleive, when you turn the steering wheel there is a noise from it like a grinding sound also when i look in the bottle there is fluid which is bubbly like air is getting in,when i start the car up and turn the wheel the fluid level drops but returns once engine is off is this the pump and if so what am i lookin at in £££'s.
    cheers
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    I've had two Veccy Bs and both times the pump sounded noisey - think it's just the way they are - bubbles could be air in the system or just the fluid being returned to the reservior - would expect the fluid to drop with steering on lock as more fluid is needed
    Vec Bs normally weep from the seals on the rack so if the fluid is staying on the marks as per handbook i wouldn't be to worried
    Planet Earth
    Trim : Exclusive
    Engine : 1.8i vvt
    Mileage : 37,500
    i have run the engine to make the fluid drop topped it right to the top and put on the screw lid,i then turned the engine off and allowed the fluid to come out over the overfill hole and wiped up it has stopped the noise and the fluid seems to be at a decent level for now lets see it is still booked into the gargae on the 6th so watch this space.
    Nov 2005
    Somewhere in time
    Careful that you don't overfill or you may damage seals in the rack,pump etc...
    Planet Earth
    Trim : Exclusive
    Engine : 1.8i vvt
    Mileage : 37,500
    hi would you suggest i take alittle out then stig?
    how high should the fluid be no markings like radiator bottle so unsure?
    Nov 2005
    Somewhere in time
    Markings are on the dipstick which is attached to the lid of the reservoir...
  1. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  2. whirring noise from power steering
    By Matt_Bankier in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2011, 21:48
  3. Help!! Power steering making strange noise
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 22:19
  4. Power steering pump noise - brand new car
    By Jaffatubes in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2007, 09:55
  5. power steering noise ?
    By shillbag in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2006, 16:33
