Thread: Cruise control
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    confused Cruise control
    Got back from France last night after a weeks carp fishing , i'm totally knackered !!!!!!!!!!! (don't ask how many i caught ! ).
    Clocked up 1041 miles & the car never missed a beat !
    BUT...................
    Had a little incident with the cruise control.
    At one stage it wouldn't activate.
    When we stopped at some services, on restarting the journey, it decided to work & did so all the way home !
    Does anyone know what happened ?
    Have you had it happen ?
    Regular Member j1 wyx's Avatar
    Gosport-Hants
    yep.........we had it happen a few weeks ago, put it on tec-2 and it had trouble codes stored!!!!! so they were cleared and it now works a treat.
    Regular Member Stu14t's Avatar
    Perth, Scotland
    same with me though no trouble codes on the Tech2. I put it down to a glitch.
    There is a poll here: Here
    Apr 2006
    North Wales
    Once the car is started you need to press the brake at least once to activate cruise control.
    Feb 2007
    Nuneaton
    I had a problem with CC too. But the reason was – clutch pedal spring play out. CC stops when you press clutch or brake pedal (keep you feet from those pedals when you are on CC ). The sensor which detect those movements requires that pedal travel far back when released. Sometimes the spring is too weak to reach it.
    The spring cost about 10 quid but the garage would charge you for the labour.
    Regular Member stickshift's Avatar
    North London
    Quote Originally Posted by alex_r View Post
    Takes five minutes to fit yourself check this link http://www.vectra-c.com/forum/showth...=clutch+spring
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    Quote Originally Posted by davidcdti View Post
    I had a rather large box trailor on and believe me i test the brakes before i get upto motorway speeds !
    There's been no problems with it since it first happened. I think that switching off the engine when we went to the services did the trick.
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
