Results 1 to 10 of 18
Thread: Cruise control newbie
    Washington
    Default Cruise control newbie
    Hello people, just got a Vx-c, and cant get cruise to work. Don't know if it's me or the car.
    Anyway, when switching on the ignition, there is NO cruise control illuminator anywhere. Is that meant to come on???
    Followed the instructions in the manual but nothing.
    Don't understand previous threads about pulling the clutch. I Have tried pressing the brake before using CC but thats useless.
    Still got 19 mnths on Warranty thankgod.
    Any ideas...is it me???
    Much appreciated.
    East Midlands
    Cruise control only works when you are above a certain speed, this is normally about 20 mph. When you are at a desired speed you then set the cruise control via the indicator stalk and the light will illuminate on the dashboard.
    Once the cruse control is set they you can use the speed control to either go faster or slower.
    As far as i can remember the "s" button is to lock the speed.
    Regular Member PTC8's Avatar
    East Yorkshire Nr Hull
    You migh have the same problem as i had when i picked mine up mate, your return spring on the clutch or brake pedal is a bit past it.
    When driving, put your foot behind the clutch or brake pedal and lift it towards you, then give your cruise a try again. Bear in mind, i think cruise will not work unless you are going more then 30mph.
    Cruise control will not work if you press the brake or clutch. If the pedal is not coming right back up the sensers are thinking that you have your foot on it.
    If you have warranty left them take it straight back. I got mine repaired under warranty so it shouldnt be a issue.
    Hope this helps mate.
    East Midlands
    if all fails take it back under warranty, might be a faulty brake sensor.
    Regular Member Stu14t's Avatar
    Perth, Scotland
    Are you moving above 30mph when you try to engage the CC?
    It will not work until you are.
    If not then you can try flicking the clutch and brake pedals the wrong way with your toes (towards you rather than pushing them) as there are switches that are used to disengage the system when you push the pedals.
    If not, go the VX and they should sort it if it's still under warranty.
    Perth, Scotland
    me Too slow again
    Washington
    Thankyou so much. It Worked!!! I pulled the clutch up and then the CC light came on and works just fine as pointed out. Very Happy Thankyou.
    But I've just discovered that the Nav panel buttons i.e Navi/BC/Audio/Sound etc and the Dial do NOT illuminate at night. Is it supposed to??? I can't see anything.
    When driving, there is a computer display showing fuel consumption etc. I tried pressing Navi for the map but it didn't work, neither did the others around there.
    Is it me?? Sorry for asking.
    Thankyou
    Full Member Big Sig's Avatar
    They should work, take it back to get it fixed
    Regular Member stickshift's Avatar
    North London
    Quote Originally Posted by ace View Post
    The problem will return, have a look at this thread http://www.vectra-c.com/forum/showth...=clutch+spring
    It should sort it for you.
    Oct 2006
    Wellingborough
    Thankyou
    If you turn the CD70 off you still get the trip computer,but audio Nav and the lights turn off.
  1. Cruise control.
    By Hyperhart in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 20:02
  2. Cruise Control
    By hopkinson06 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2009, 18:03
  3. cruise control??
    By Mads in forum General Chat
    Last Post: 6th July 2008, 11:47
  4. Cruise Control?!
    By Mads in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2008, 11:29
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
