Results 1 to 3 of 3
Thread: EGR valve on 2.2 dti
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Default EGR valve on 2.2 dti
    as above just wondering if this is a common problem on the 2.2 dti as my brothers signum has broken down and according to the AA the fault code leads to the egr valve. the car was coughing anmd spluttering and running very roughly and losing power, hes just returned from 2 weeks away touring cornwall, then the lake district and the car finally died 250 yards from his house, has anyone else had this problem
    Feb 2006
    Guttedsville
    Kind of in the past. Whip it off, give it a real lashing of carb cleaner, let it dry out before refitting it. They can coke up a little bit which causes problems.
    It's literally a case of whip the cover off and undo the two bolts that hold it in. Withdraw it carefully and spray at will!!
    May get a few comedy pops and bangs when reassembled, if this works at all.
    Worth a try.
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Quote Originally Posted by Andrew's ? View Post
    Worth a try.
    will pass that on andrew as car is currently stored at local independant garage awaiting proper diagnosis
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
