Thread: Problems with the NCDC 2013 4CD Multichanger
    Regular Member David_SRi_2.2DTi's Avatar
    Jun 2007
    Leeds
    confused Problems with the NCDC 2013 4CD Multichanger
    Has anyone experienced any problems with this? I put four discs in it the other day, and two of them wouldn't read, producing a "cd error" message. It wasn't the CD, as I took it out and put it in the single slot at the top of the unit and it plays fine. The ones that do play in the multichanger jump quite a bit too, is there any way of cleaning the mechanism (not sure if this is the problem)?
    you could try a cd 'head cleaning' disc in all four slots.. i got one from woolworths and it improved the reproduction on mine....
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    I had a problem like that on my old CDX and they changed it under warranty, said it was U/S
    Jun 2007
    Leeds
    ...sounds like a good plan . The car is on a 53 plate so I don't think I'll be able to claim under the warranty!
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    I know when I had mine it hated copied CD's (back ups of originals that stayed safely at home in case the car was broken into) ... I had a couple of brands that would work quite well but even then I had the occaisional jump ... yet as you say the single slot Sat Nav/CD Player at the top played the discs fine. If you are using copied CD's then that may be your problem.
    Dave
  1. Ncdc 2013
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2010, 00:05
  2. ncdc 2013 problems
    By adfrodsham in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2009, 18:49
  3. NCDC 2013 sat nav
    By Dwabo in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2008, 21:32
