Thread: windscreen wipers stopped working
    Regular Member dazzer t's Avatar
    stoke on trent
    confused windscreen wipers stopped working
    hope some one can help me here.
    driving along in the rain this morning with the wipers on i noticed that they were starting to slow down then speed up again, then all at once they stopped and would'nt work at all, but every now and then they try to move a little bit, also my windscreen washers have stopped working.
    i have checked all the fuses and connections i can see, when the stalk is moved i can hear the contactor clicking but no movement from the wipers.
    i have just dissconected the battery for a bit and will see if that does anything.
    any ideas would be very much appreciated.
    thanks in advance daz.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Washers are a common problem that is usually down to a build up of gook on the motor filter. Bit of a coincidence them both stopping but the washer motor can be found behind the front, nearside wheel arche liner under the headlight. Lift the motor vertically out of its locating rubber seal & clean the filter in warm water
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    that little gem of advice cost me a tenner at the stealers until i complained. then it was taken off......
    stoke on trent
    Quote Originally Posted by Ian S100 View Post
    cheers for that one mate but i have just done what you suggested and its still not working. looks like it will have to go to the dealers as its still under warranty
    Mar 2007
    belfast
    Had a similar problem with my wipers ! they eventually stopped in the middle of the windscreen! the car was off the road for 6 weeks while vauxhall got the part! Think it was some kind of control box.Hopefully you wont have this problem!
    stoke on trent
    Quote Originally Posted by sambo View Post
    looks like the same problem mate did your washers stop working aswell?.
    Mar 2007
    belfast
    They did stop working too ! I was shocked that it took so long to get a part.They did give me an 07 zafira while my car was in the workshop!Good luck
    stoke on trent
    any idea where this control box is situated?
  1. windscreen wipers & washer not working properly
    By bootneck85 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2015, 07:43
  2. My front wipers have just stopped working :-(
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd January 2013, 13:25
  3. Windscreen washers stopped working
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 18:10
  4. Wipers have stopped working
    By myhotholden in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2008, 03:44
  5. wipers stopped working
    By otl1uk in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2008, 10:46
