Results 1 to 10 of 13
Thread: Temporary loss of power 2.0dti
    Mar 2007
    dublin
    Default Temporary loss of power 2.0dti
    Hi
    Yesterday morning got into the car to go to work, it wouldnt rev and didnt have any power , wouldnd rev past 2000rpm in neutral and there was a spanner warning light on the dash, I was stuch in heavy traffic then and after about 15 mins light went off and the power came back, what could have happened?
    Nicking Ya Dinner.
    Mass air meter.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    or a split vac hose
    Nicking Ya Dinner.
    Quote Originally Posted by JuzzyD View Post
    or a split vac hose
    Yeah, have a listen if you can hear hissing/suction noises.
    Mar 2007
    dublin
    The car has run ok since yesterday, ill have a look at the hoses for a start
    Regular Member tonypc1's Avatar
    on the long road to ruin
    i was having problems with the running on my 2.0dti sig and it was a couple of perished rubber conectors on the vacuums. i also changed to shell extra diesel from supermarket fuel based on recommendations on this site and the car is getting better and better. Have a good check of the rubbers as even the smallest hole will cause problems. if in doubt change them any way as thyre inexpensive and its one less thing to worry about
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    If u have a split in your vac hoses u can sometimes agitate it by holding down the brake pedal depleting the air in the servo whilst the vacuum servo thingy cant replace it fast enuff, this will bring on the EML, had 2 cars do this to me now.
    london
    My spanner light has come on twice in the last three weeks, usually when accelerating at about 70 mph. I pull over and stop, switch off, switch on again, spanner light goes out. The hoses seemed fine, any other ideas?
    Quote Originally Posted by motorchoke1 View Post
    thats exactly what mine was doing,i'd suggest checking the hoses again. there are two vacuum switch type arrangements fixed to the front panel near to the front of the battery cover. they both have two vacuum pipes,i found that on one of them both the rubber conectors were perished, i changed these with some rubber pipe from a motor factors for 20 pence and it sorted it.
    Mar 2007
    dublin
    It started again today when the missus was driving, checked hoses on the front panel in front of the battery and one of the hoses is perished, ill fix that and see how it goes, also when the car is driving and looses power when i turn ignition off and back on power returns
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Loss of power - 2.0DTI
    By mcally in forum Engine & Drivetrain
    Last Post: 4th November 2012, 18:55
  3. Temporary Loss of power in 1st gear
    By Envy in forum Engine & Drivetrain
    Last Post: 24th October 2010, 22:24
  4. Temporary loss of power
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2010, 22:40
  5. power loss when driving in a 2.0dti 53reg
    By 1rsm in forum Engine & Drivetrain
    Last Post: 29th December 2007, 19:34
