Thread: Please need help to install headunit!!!
    Jun 2007
    Bromley
    Default Please need help to install headunit!!!
    Hi All,
    I tried to install a double din dvd player in my vectra 2004 (1.9 cdti sxi).First I removed my old CDR2005. I plug-in the iso harness from the dvd headunit to the car (without using any extra adapter). There is power but no sound!!! I tried also a pioneer mp3 headunit and I still have the same problem. Anyone can help me? thanks
    Here, there and every where!
    You need a quadlock to iso adapter harness m8
    http://www.incarexpress.co.uk/view_p...?partno=PC2854
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You need to have the old unit programmed out using a Tech 2 as well. There will be no end of problems otherwise. Also the unit you take out will not work in any other car unless it is programmed out. The units sell well on ebay. I was lucky installing my head unit as it was one the first Vectra C's that did not have quadlock but ISO instead so it was plug and play. Check with your dealer to make sure tho.
    Not strictly true m8, you can remove the old headunit WITHOUT Tech 2 and the new system will work ok but the old unit, as you said, will not work in another car unless it has been de-programmed from your car
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Are CDR2005's on quadlock?
    If it's a 2004 then it might be
    Regular Member graham a's Avatar
    hull
    always thought that the latest head units,such as the cd30,cd40 and cd70 had to be tech 2.i fitted a ccr 2006 out of a 54 reg vec into my 53 reg vec with no probs.
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Quote Originally Posted by Ben H View Post
    Think they are the ISO plugs with the extra 20 pin plug moulded on top for display / stalk controls etc
    cdr 2005 is not quadlock cd 30 etc are
    Jun 2007
    Bromley
    problem resolved, the headunit was faulty! thanks for the answers.
  1. new install in the vec
    By bensterzback in forum Quick Photo Album
    Last Post: 18th October 2010, 21:10
  2. REQUIRED - Instructions to install Sony Headunit
    By 12345 in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2009, 14:18
  3. Vectra Headunit Install - help!
    By KillaFish in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2007, 03:47
  4. Dash Light Problem After Headunit Install
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2007, 09:34
  5. New Headunit Install
    By Elite2.2DTi in forum ICE Gallery
    Last Post: 1st December 2006, 21:01
