Thread: Traction/ESP light on in the wet
    Jun 2007
    Southend-on-Sea
    Default Traction/ESP light on in the wet
    Every now and again, when I start my car, the traction/ESP warning light comes on. Sometimes it goes out after a while but more often than not remains on for the entire journey. In the majority of cases it happens after a heavy downpour. Any ideas what the problem could be?
    Thanks!
    It should come on during the POST and then go off along with all the other sensor lights
    If it stays on and remains on, then either the TC button has been pressed (switching TC off) or the sensors are faulty
    However, the ABS light would normally stay on as well, as they are part of the same circuit
    It might have been unsettled on brake pad change, so well worth having it looked at
    Jun 2007
    Southend-on-Sea
    Thanks. Pads were changed recently so that seems a logical place to start.
    Regular Member sophos9's Avatar
    Norfolk
    Daave.... stop giving it so much teddy in the wet, it comes on to let you know your are spinning up ha ha
  1. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  2. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  3. ABS and Traction Light On Together
    By sjanisz in forum Engine & Drivetrain
    Last Post: 3rd March 2010, 15:09
  4. Traction light
    By viki_3.2 in forum Suspension, Wheels & Brakes
    Last Post: 21st December 2009, 09:34
  5. Traction light
    By Monza30 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2008, 23:37
vauxhall signum traction esp light
vauxhall limp mode reset
