Results 1 to 10 of 14
Thread: gsi 3.2 niggles
    middlesbrough
    Default gsi 3.2 niggles
    Hi got a few niggles with the car at the moment first one is when i start the car i can hear a squeeky noise as the engine turns over maybe a belt, the second one is first thing in the morning or after been stood for a time when i turn the key the engine fires up, but for up to 5 seconds later the engine is stuttering badly and then revs normally any ideas, the car is still under manufacturers warranty and also network q till jan do you think the problems will be covered by these.
    morton
    your squeak sounds like a pulley belt !? but the idle issue is a trip back to the stealers ! if its under waranty use it ! thats my motto !!
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    when i start mine up first thing the engine judders abit like its firing on 4 cyinders then settles after a few seconds.
    but no noise
    if u not sure get it in to the dealers if still under warranty
    middlesbrough
    Thanks mine has only just started doing this within the last month it only happens after been stood for 10 hours or more it always starts, the only way i can describe it is its like the days when you had a choke and you flooded the engine for the first few seconds, i have every intention of using the warranty i just dont want to here sorry sir thats not covered.
    thats because now they don't have a choke, they have to run the injectors VERY rich to keep the engine running..it's normal for it to run rough for the first few seconds while it's still on it's cold start cycle..i'd only be concerned if it ran rough after 30 seconds
    middlesbrough
    GSI 3.2 when you say its normal for it to be rough for the first few seconds the car never used to be like this, i bought the car in january and it started fine in the cold months, the engine fires straight away but theres nothing there its like its going to conk out for a few seconds during which time im trying to rev it but nothings happening then all of a sudden its ok.
    define 'rough ' for me.. do you mean it's slightly 'hunting' for a while, or do you mean it's like it's running on 4 cylinders and shaking quite a lot??..
    .. oh the fun of long range diagnosis....
    middlesbrough
    I wouldnt say it was firing on 4 cylinders and shaking its as though the car has started and the revs are very low 250 on the verge of stalling im pressing the throttle and the car is not responding add after 3 to5 seconds it responds and the revs go up.
    SOMERSET
    Quote Originally Posted by Alan View Post
    I have had this with mine only now and again and it does just exactly what you described, go to rev it and nothing and before now it has stalled on me. Has'nt done it in ages so iam not bothered by it.
    Feb 2007
    Nottingham
    Thumbs up Gsi Idling Issues
    Higher,
    It sounds like a fuel filter issue/fuel contamination issue , try to use the same petrol station as some outlets are better than others. I find Esso is good fuel and my car has neaver shown any of the symtoms you describe.
    Regards,
    JCB
  1. A few niggles
    By Cruize in forum Vectra C / Signum Troubleshooting
    Last Post: 27th January 2012, 14:10
  2. A few little niggles
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 15th March 2011, 21:25
  3. Few niggles GSi 3.2 - Help!!!
    By del3.2 in forum Engine & Drivetrain
    Last Post: 3rd December 2010, 21:06
  4. few little niggles
    By jossyboy in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 09:24
  5. A few niggles
    By v6boy in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2006, 20:50
