Thread: Gear change
    Jun 2007
    west yorkshire
    Default Gear change
    Hi
    I got turbo gasket replaced yesterday so was listening to see if it was ok but i normally have music on but what i noticed was when i change gears it makes a faint noise which sounds like ball bearings are moving or something. Its not grindin and gear change is fine. Hear it more when going into 5th like its something is rolling. i hear from the where the gear knob is and not the engine.
    Is this something to worry about? is this standard vauxhall gearbox.
    i had the car pressure washed yesterday as there was alot of oil due to leak
    any advise would be great
    cheers
    TJ
    Jun 2007
    west yorkshire
    just got it checked from garage they said nothing to worry about. said noise is the linkages in the gear knob bit
    only really happens when i change gear into 3rd/4th 5th but 5th is more noticeable! cos i keep the gear pressed with hand but if i let go off gear stick it is ok
    morton
    he he ! driver error then ?! he he
    Jun 2007
    west yorkshire
    i know! lol!
    but never heard it before but should hopefully be ok
    have you heard of this before?
    morton
    try driving an old beemer with rear wheel drive and 200k on the clock ! then you'll here some whine !! lol
    pull up the gaitor and have a look down the gearchange..you'll soon see if anything is wrong....but don't worry , it won't be related to having a turbo gasket changed..
    Jun 2007
    west yorkshire
    Hi
    I am just curious about the issue i orginally stated.
    I drove this morning and when i first change into 5th it squeaks but after that i hear the same noise when i change the gear only as above. The noise as stated above comes from the gear stick bit.
    But gear change is smooth no problems there
    just wanted to know what could possibly cause this?
    cheers
    TJ
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. 1.8 vvt gear change
    By davidpickard in forum Engine & Drivetrain
    Last Post: 12th December 2011, 12:16
  3. gear change
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 09:31
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. change gear
    By aptoman in forum Engine & Drivetrain
    Last Post: 3rd June 2008, 23:16
