Results 1 to 10 of 14
Thread: Front Brake Pad Replacements
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Smile Front Brake Pad Replacements
    I'm now armed with my 7mm allen key and rewind tool, courtesy of ebay. So I'm ready to replace the front pads (I thinks). But wheres the safest place to put the stands ?
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    http://forum.vectra-c.com/showthread.php?t=15091
    Check out this How2, The first picture shows you where Mark put the axle stand.
    Hope this helps.
    and if that isn't clear, then place them under the metal subframe and not under the cars floorpan as they'll bend it..
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Thanks for advice. I'm assuming the pads need replacing as when I brake I get a grinding noise from the NSF. Its more apparent when the cars is full of bodies or I brake heavily. Like a dull groan, the way I feel when I have to go to work. But strangely, I dont get the noise when its wet only when its dry, Bizarre. !!!
    Any ideas ?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    If the pads are down to the metal you will probably need discs aswell - what sort of mileage has the car done?
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Cars done 50K, but had the original front pads replaced at around 32k..
    morton
    they havent lasted long then matey ! are you the king of the late brakers ? my wifes the queen ! he he
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Talking
    I've been told that I drive like an old women, thats why I'm suprised about the brakes. I'll have to check the brakes and make sure they are evenly worn.
    morton
    strange ! people who drive steady who's brakes ive done are normally in worse condition ! i presume its due to lack of movement which allows rust , dirt etc to settle in !?
    Regular Member rozzer1976's Avatar
    Feb 2007
    Lanarkshire
    Vehicle : Vauxhall Astra
    Trim : SE
    Engine : 1.7 ecoflex cdti
    Year : 62
    32k???? You are indeed the King of the late brakers! Im changing mine for the first time at 66000. My discs look not too bad but a small lip has formed so im changing them anyway.
  2. Factory Standard HID replacements
    By Blade1000 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2012, 12:56
  3. Brighter bulb replacements ??
    By Hammy in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2010, 21:21
  4. Do you have broken air vents? Replacements here
    By merikiito in forum Parts for sale
    Last Post: 2nd November 2008, 18:01
  5. Best replacements for OEM bulbs?
    By stehanson in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2006, 13:42
