Results 1 to 10 of 11
Thread: indicators stuck on even with ignition off
    orkney
    Default indicators stuck on even with ignition off
    hi, ive just bought a 2.5 v6 cdx vectra with the indicators and repeaters all stuck on but not flashing when the ignition is turned off also the hazards dont work with the ign, off. With the ign, on all works normally, also the power window switches are illuminated with the ign, off.. any ideas would be very welcome ..
    Regular Member deez_nutts's Avatar
    Jun 2007
    Wiltshire
    im not sure i understand this very well...anyway
    Indicators are not supposed to work with ingnition off but hazard should.
    Does the indicator work ok with the ignition on?
    Would this happen to be a Vectra B?
    If so, the indicator relay has failed
    Admin plasma's Avatar
    On the Forum
    267 Post(s)
    Engine : 150
    Mileage : 74000
    yes, i reckon so, he said cdx.. so its on a 'b'
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Very common fault. Open the fuse box cover by the drivers right knee. Inside you'll see two yellow relays next to each other, one is for each side of the car. One is either duff or stuck.
    Got fed up with the neighbours alarm going off as it was draining the battery. He'd had a mechanic out scratching his head for last hour when I went out, pulled one out, gave it a tap on the ground, put it back in and it was fixed.
    Mechanic wern't best pleased.
    orkney
    yes the indicators and hazards work with ign, on but the problem is all 4 indicators come on steady when you switch off the ign even with key out
    orkney
    yes iv,e looked at the relays but wouldnt a faulty or stuck one only cause one side to malfunction and with the ign on they all work perfectly . Also when the ign is off and you switch on the hazards the switch lights up but non of the lamps flash. The car has stood with a flat battery for months and then been started with a booster (not by me) so i am wondering if its damaged an ecu..
    orkney
    also, does anybody know where the diagnostic socket is ive had half the dash out and looked under the bonnet with no luck..
    On the Forum
    267 Post(s)
    Engine : 150
    Mileage : 74000
    ODB port is underneath the coin holder tray on the centre console, u pull it upwards from the end nearest the gearstick, it has 2 metal spring clips, careful not to loose them,
    Herts\Beds Border
    Quote Originally Posted by listerd View Post
    Perhaps both have gone faulty if stood around. I did read they are a common problem.
  1. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  2. Help with indicators!
    By Ricksh in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 07:15
  3. indicators,,,,,,
    By kpf1grandprix in forum Insignia car chat
    Last Post: 19th February 2010, 01:11
  4. Indicators
    By VauxVeteran in forum Insignia car chat
    Last Post: 24th June 2009, 20:05
  5. Pressing the indicators when ignition off....
    By joejdx in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2009, 22:40
http:www.vectra-c.comforumshowthread.php27310-indicators-stuck-on-even-with-ignition-off
vectra b indicator stuck on
