Results 1 to 10 of 13
Thread: funny vibration when driving
    bradford, west yorkshire
    Default funny vibration when driving
    hi I'm New To The Forum And Have Recently Bought A 2002 52 Plate Vectra 2.2 Sri.
    i Have A Problem With It And I'm Hoping Some One Can Help.
    whilst Driveing The Car I Get A Viberation Coming From Either The Engine Or The Gearbox. I Had It Checked By Severa Mechanics And They Told Me Its Either The Spark Plugs Or The Coil Pack, So I Had The Car Serviced Using All Genuine Dealer Parts And The Problem Is Still There.
    it Feels Like A Missfire But Don't Think It Is. It Some Times Goes Away And The Car Drives And Pulls Really Well, But Soon Comes Back.
    could Any Body Help With My Problem Or Has Any 1 Had A Similar Problem?
    thanks,zed.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    your pm box is full mate so here is the pm i would have sent you ....
    does the vibration change or go away when you press the clutch pedal all the way down .?
    if so could be the flywheel .if it is still there maybe a enigne misfire if you have changed the plugs and the dis pack chances are you have a problem with the chain on the engine but i would advise looking at the flywheel first as this is a common problem on the vec c model and they dont seem to suffer with the chain problem as in the early cars (vec b) a good thing is to have a walk around the back of some dealers and talk to the mechanics direct and offer them the job on the side to have a look or replace any parts this maybe youronly way to get a good bloke and the job done cheap hope this helps benny
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I've replied to your PM also zeadly. Much the same as benny has just said.
    Jun 2007
    Sittingbourne, Kent
    Quote Originally Posted by zeadly View Post
    thanks,zed.
    mate , smart writing .
    thanks,zed.
    BENNY, THANKS FOR THE REPLY.
    THE VIBERATION IS STILL THERE WHEN THE CLUTCH IS PRESSED.
    SOME TIMES THE VIBERATION GOES AWAY BUT SOON RETURNS.
    ALSO WHEN THE CAR IS STATIONARY IT IDLES.
    THE REV NEEDLE DOES'NT MOVE UP OR DOWN.
    TOOK IT TO PUT IT ON A FAULT FINDER COMPUTER AND IT SHOWED TWO FAULTS,P1523: THROTTLE CONTROL CIRCUIT MALLFUNCTION AND P0202: INJECTOR CYLINDER MALLFUNCTION.
    THE CODES WERE ERASED BUT HAVE BEEN TOLD TO BRING IT BACK IN TO HAVE IT RE CHECKED ON MONDAY.
    THE VIBERATION IS MAINLY BETWEEN 1500-2000 RPM.
    SOMERSET
    to the site
    the injector code makes me think that one of the injectors is failing.. you would be well advised to get them checked out, as well as their wiring..
    thanks for the advice mark.
    checked all the injectors and the wiring and they all seem to be working fine.
    have taken it to loads of different garages but can't find the fault.
    when the clutch is pressed and car is reved the viberation is still there.
    Aug 2007
    bournemouth
    Did you sort the problem? My 2.2 Sri has started doing the same after making a lot of noise when starting. The garage has run diags but says everything looks fine. They think the timing chain may have jumped some teeth on the balance shafts when the engine started and made the original noise. Performance seems ok. Looking at other threads the dual mass flywheel seems to cause vibration right through the rev range when that becomes faulty.
    Vehicle : SRi
    Mileage : 137000
    Think it turned out to be his flywheel.
  1. Replies: 2
    Last Post: 28th July 2011, 13:37
  2. engine sounds funny when driving
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 20:38
  3. limp mode on motorway driving.....driving me crazy!
    By big rich in forum Diesel Engine related
    Last Post: 27th August 2010, 05:24
  4. Funny thing happened tonight on the way home !! Not Ha Ha Funny !!
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2008, 02:26
