Thread: Touch up Aerosol Spray application
    Regular Member denzo's Avatar
    Runcorn
    Default Touch up Aerosol Spray application
    Hi.
    I was unhappy with the local chipsaway guy's try to repaint a good silled dent in my rear wheel arch ...
    There was excessive overspray and some general clumsliness.
    Can't be bothered getting the guy back for a seconf attempt.
    I've managed to remove all the overspray and most of the paint he applied (vigorous polishing with Autoglym).
    Got a tin of genuine spray paint n order from the dealer for me to have a go myself.
    Any hints and tips at how I can do this ....
    Obviously I will be masking and protecting from overspray.
    Only a small area to spray .... which is why i fancy having a go myself
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Read the instructions on the tin, and have a practice first on some other than your car held in the same orientation..
    post a picture of the area you'll be spraying.... we'll be able to give better advice then.
    Nicking Ya Dinner.
    I used to do coach painting for the 1st eleven mths I was working after I left school.
    I'm not sure how well you will get on with a rattle can, but have you considered a modeling mini spray gun, like a pencil with a small paint bowl attached to it and fired by compressed air from a can.
    Anyway
    A few tips
    When painting, always move in straight horizontal lines and overlap, and try to keep the distance and the time to sweep consistent, you might also want to boil the kettle and drop the can in the hot water for a few minutes, then shake like mad, do a tester 1st before you hit the car with this method, the whole idea is to thin the paint, so you need to get a comfy technique going so you don't end up with lots of runs. hth.
  1. Freeware Application
    By Damian in forum General Chat
    Last Post: 11th June 2012, 00:22
  2. Aerosol spray - Finish
    By moorlander in forum Bodywork & Interior
    Last Post: 3rd July 2009, 11:54
  3. job application
    By steve.s in forum General Chat
    Last Post: 11th May 2007, 14:25
  4. Application for a night out
    By CPHB in forum Comedy & Humour
    Last Post: 18th May 2006, 00:56
