we need confirmation...............god dammit.
if someone gets one - I'll pay £5 to borrow it.
then I would know.
then I would know.
Guys, if anyone is passing by me sometime, or goes to any meets I’m at, I will happily test it out, the next big meet I know of at the moment, that I am going to, is Trax.
Indeed, not when you're around to do it for me.
The Uiftech range right up to th U581 with freeze frame and live will only do engine codes...
If you want ABS and Immob you will have to look at the ELM327 CAN Bus with VauxCheck software
Anything above and beyond that and you will have to look at a VAUX-COM or Tech2 with CANdi. The VAUX-COM gives near dealer access at £550
So will this:
http://cgi.ebay.co.uk/CAN-Bus-OBDII-...ayphotohosting
Work with my 03 2.2DTi...??
So confused about this.... I have the 3 buttons on the side of the steering wheel... and a data port under the ashtray.
If it will not work, any ideas on what to look for?
Cheers.
Matt
that will work on your car, yes..
it states that it's OBDII compliant and works with CAN systems, so it should work on yours..
The U581 is a good unit, does limited live data and freeze frame which is great. Will give you engine codes and as its multiprotocol will work with other cars too!
