Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: fog switch
    North West
    Default fog switch
    can anyone recommend a switch with a part number so that i can operate my self install foglights on an LS MODEL.
    I Seen this in part numbers section
    Blank Switch (replaces TC switch)
    1313207
    would that switch do it? i'm asuming i need to use one of them switches by the radio/cd unit
    ps: i need part number for the connectors to each foglight(think they are called spade connectors
    manny many thanks
    Regular Member danlat1415's Avatar
    Lancashire
    You'll be best having one of these:
    Its a headlight/foglight switch that goes by the right hand side of steering wheel. You're is probably the same, but without the foglight switch (top left button)
    Just replace your headlight switch for this one, and connect the wires from your self installed foglights to that button. Not taken mine out, so don't know what it looks like, but somebody will tell you how it's connected.
    Search on Ebay for "Vectra c fog switch" you'll usually find some on there, or go to a salvage yard.
    Jan 2006
    Skynet HQ EMEC#5
    I think you will find that
    1313207
    is actually the blank cover as fitted if you do not have a TC switch
    Regular Member Eddy R's Avatar
    Aug 2007
    Hawick Scotland
    Did you manage to get these lights fitted and working on the LS ?
    eddy
    North West
    I have them fitted but i haven't wired them up yet,i have bought a switch like the one in the picture but i don't think it will just work if i connect them up.
    There is a way to fit them,as i have seen an LS on my travels with fogs lit up!!
    Aug 2007
    Hawick Scotland
    Hi
    I got the fogs and the switch fitted and even got the loom to connect them to the connector to the right of the radiator which replaces the loom that runs to what I think is the air temperature sensor.
    All connected and they don’t work although I have been told the ecu needs to be told the lights are there.
    I am going into the Local dealer tomorrow afternoon and there going to have a look.
    On the phone he recons it’s a 2 min job for them and will cost Approx £25 to do.
    I will let you know how it goes
    Eddy
    Regular Member Marty J CDTI's Avatar
    Feb 2006
    Yeovil
    2min=£25 thats shocking I'm buying a Tech-2 machine, shall we all chip in we could save a fortune! thats 21p a second!
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    Smile fog lights
    i upgraded my ls and bought a rocker switch of ebay around 3pounds connected them direct of the battery using a wireing kit also off ebay 5pounds takes about 30mins to do if you check out the how do section on here there is a tread that armour farmer done to show everone how easy it is any help email me
    regards nigel
    North West
    i got told by vx that i would need a new ECU WHATEVER THAT IS,said it wouldcost an arm and a leg ,not worth doing.
    couldnt i just connect it up to the rear fog light,then 1 switch and they all come on front and back
    Thumbs up switch
    hope this helps
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. t/c switch help
    By kitchcav in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:02
