Thread: black front screen skirt
    northampton
    Default black front screen skirt
    Does anyone know how to remove the black front sceen skirt(cover) on a vectra 04 plate? I,ve had a look tonight but it was stuck solid....!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Do you mean the scuttle panel? The bit that the wipers come out of.
    northampton
    yer thats the one, Any ideas?
    Vehicle : SRi
    Mileage : 137000
    Never had mine off but I've just popped out to the car and looking at this thread
    http://www.vectra-c.com/forum/showthread.php?t=15125 it look like you just take off the wiper arms and rubber strip and slowly pull it away.
    [Ex]Admin Duncan's Avatar
    Yep, remove the wipers - they can sometimes be partly seized and be a to remove so always an idea to pop a bit of Copaslip on the splines when they're off.
    Get a plastic spatula or similar and run between it along where the panel meets the screen glass, just to release it and unclip it.
    Then carefully flex the panel to allow the end bits to clear the bodywork, being very careful not to flex too much as the honeycomb section is the weakest point and can crack - as I found out when refitting mine in a hurry!
    Reverse procedure to refit, again being careful not to flex too much.
  1. Xp Lower Front Skirt.
    By PORKBALLS29 in forum Styling
    Last Post: 6th July 2010, 22:31
  2. Front skirt trim
    By Gonch in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2007, 14:02
  3. Front Skirt
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2007, 22:25
