Results 1 to 10 of 23
Thread: New Speedo
    Jun 2007
    Surrey
    Default New Speedo
    Hi i'm new to the forums i have commented on some topics..
    I recently bought some second hand dials the silver circled ones.
    The person that I bought them off doesnt have the security code. Just wondering if there is any other way to find this out as they came out of a scrapped car. And doesnt even know the Reg.
    I have a friend that works for VX and he does minor jobs for me and he fitted them and they show 19k but mine is on 96k and is a 02reg.
    What i'm asking is there no way of finding out the code to reset it?
    Many thanks
    James
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    I'd like to know this myself mate, but I thought it was simply a case of plugging in to tech2 to reset the mileage?
    Full Member Big Sig's Avatar
    I thought you could only adjust the mileage in new clocks with less than 200 miles on them? Otherwise clocking them would be tooooo simple.
    Jun 2007
    Surrey
    yeah you need tech 2 which i sort of have access to but its this ****** security code on the clocks...
    morton
    bound to be some puter smart a**E ! who can get round this problem !!?
    Engine : Z20NET
    Didn't seem Necessary to create a new thread...
    I'm still looking at getting a new set of clocks with the silver rings fitted, I've sourced a set of 170MPH clocks out of a 2004 car with the silver rings fitted, before I fit them to the car I'm having a conversion done on them to run with blue l.e.d's so there's time to discuss,
    What I need to know about is the mileage issue, I don't want to bang a set of clocks into my car that have a different mileage to my car, I want it all to be accurate and correct, if I take these new clocks to Vauxhall can they correct the mileage so they display the same mileage as my current clocks? I.E - Via Tech 2 or some other programming source they have? or is there something else I need to do?
    I just need to know if it's possible,
    Jun 2007
    Surrey
    You need the security code from the car they came out of. which is on the little business card thing with the books and stuff..
    Then you have to get vauxhall to try and sort it out... there is a company that can do this and they want £120 to do it
    Regular Member benny's Avatar
    Feb 2006
    dudley
    you can only adjust the milage on new clocks ..not used clocks they will always show the milage of the car they came from unless you get a milage correction company to put it right for you
    [Ex]Admin Duncan's Avatar
    Why don't you just swap over the front part of the dials - needles, graphics layer etc and keep your existing physical clocks with the correct mileage - somebody else already did this I'm sure.
    If you do keep the new clocks, unless you use a mileage correction company you're going to end up with problems if you try and sell/trade-in as the mileage will conflict with it's past history and people, including dealers, will just walk away if they think it's been clocked.
    Engine : Z20NET
    What Ducan has said sounds interesting, do you you think this would be pretty straight forward to do Duncan? just break the clocks down and transfer the necessary numbers, as I said I'm not interested in just fitting them to my car with another car's mileage, I want to do the job properly in the cheapest, most effective way possible, so if what Duncan has suggested can be done, I'd rather do it like that
  1. GPS v SPEEDO
    By savage. in forum General Chat
    Last Post: 20th April 2009, 14:23
  2. no speedo
    By frazandsaima in forum Engine & Drivetrain
    Last Post: 25th January 2009, 23:53
  3. Speedo..
    By C19_CJB in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2005, 15:37
how to code new speedo vectra c
