Thread: steering rack leak !!
    morton
    Default steering rack leak !!
    the car in question is a 2.0 DTI . the rack is leaking from the nearside gaitor area ?? been told it will need a new rack ! and that the sub frame will need to be dropped to remove it !? any help will be much appreciated folks !
    if the end seal is gone, then you may well need a new rack, depends on how bad the damage is...you don't have to remove all of the subframe, but just let the back end droop down and there should be enough room to withdraw it. Undo the column pinch bolt first.. it's tight but possible...and don't forget to fit new subframe bolts as they are the stretch type..
    morton
    thanks mark ! got a price for a replacement and there are two ! speed sensetive or not !? its an elegance model ! any ideas ? thanks
    Regular Member deez_nutts's Avatar
    Jun 2007
    Wiltshire
    i've got the same car i dont think it has speed sensitive steering.
  1. Steering Rack
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2013, 15:59
  2. Steering rack leak
    By ldanieli in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2012, 19:53
  3. Steering Rack?!
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 12:17
  4. Need a new steering rack :(
    By Xerath in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2010, 17:44
  5. Steering rack gaitor leak?
    By silver-tongue in forum Suspension, Wheels & Brakes
    Last Post: 28th February 2010, 19:40
