Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: How fast do these cars eat rear brake pads!
    Default How fast do these cars eat rear brake pads!
    I fitted brand new Discs and Pads to my car in September 2006 (well Drinky did most of the work) and this morning I heard that metal to metal sound that we all dread.
    On looking at the pads the inside pads are completely worn. The outside pads have about 4mm on them. The front pads all have loads on.
    My car seems to really eat rear pads, is this right? I reckon I've got just about 19k miles from these rears.
    Nicking Ya Dinner.
    My Omega used to take the rears out quite rapid as well.
    Sweden
    Rear pads should last longer than the front as they aint used as much.
    So it sounds like bad adjustment ...
    [Ex]Admin Duncan's Avatar
    Yep, 19K doesn't sound right for a set of rears.
    Quote Originally Posted by TechWolf View Post
    In my experience the rears have always needed replacing before the fronts.
    Full Member Big Sig's Avatar
    In my last car - VX astra, the fronts lasted 45k and the rears 61k. I have never had to replace the rears before the fronts. Does your missus drive with the handbrake on????
    Sweden
    Quote Originally Posted by AJA View Post
    Front discs & pads have a harder life than the rear .... so i should be the other way around. ( If you compare front and back wheels, the front will be more dirty due to the this )
    Regular Member R-man's Avatar
    Beds
    Quote Originally Posted by Astrase20 View Post
    Jees, you must drive extraordinarily carefully! Dont think i've ever had front pads last longer than 20k / 25k.
    I'm sure I'm right in saying that there's a few members on here who have had the same problem with the rears shot whilst the fronts are OK.
    I would change the fronts as well, but there really is quite a lot of pad left on them. Do I have a problem with front/rear brake bias?
    Regular Member simac's Avatar
    Wirral
    All my pads lasted until 43k miles, now at 59k miles the rears are making that slight dragging sound every now and then but the fronts are very thick.
    It's still on the original disks though which still look fine, but i'm expecting to change them and the pads at the next service in a few weeks.
  1. Rear Brake pads
    By tangoman in forum Suspension, Wheels & Brakes
    Last Post: 24th July 2012, 13:19
  2. Rear Brake Pads
    By IWC in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 11:55
  3. Which rear brake pads?
    By Toyotacelicagt4 in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2009, 13:44
  4. Rear Brake Pads on a 1.8
    By undecided901 in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2009, 11:08
