Results 1 to 10 of 14
Thread: Tyres ??
    Regular Member shillbag's Avatar
    Apr 2006
    Leicester
    Default Tyres ??
    does anyone have first hand knowledge of sumo st08 tyres, they are going for a great price at www.valuetyres.co.uk fitted price £114 for 2
    215/50/17 95w
    You get what you pay for really
    I would expect them to last about 5K miles on the front, maybe up to 12K miles if you fit them new to the rear and swap to the front when the fronts wear out
    Ask them for details of the treadwear / traction / temperature ratings, and compare that to what you currently have fitted
    Regular Member pbuckley's Avatar
    Lincoln
    they do not look to bad see http://www.sumofirenza.com/passenger.htm
    with treadwear rating of 360 which is at the higher end for performance tyres.
    Treadwear definition:
    Treadwear grades typically range from 60 to over 500, in twenty point increments. To receive a treadwear grade, a tyre is tested under controlled conditions on a government prescribed test course which does not necessarily simulate the actual application for which a given tyre is designed to perform. As a result of these test parameters, there is no accurate way to assign miles of wear to treadwear grade points.
    Upon completion of the 7,200 mile test, the rating results of both tests are compared, and the tyres being tested are assigned a treadwear rating by the tyre manufacturer. A tyre with a treadwear grade of 400 might be expected to last twice as long as a tyre that has a grade of 200 if given the same usage and driving style.
    Apr 2006
    Leicester
    i think they are a bargin, but need to compare the treadwear/traction/temp ratings of my current michelin pilot premacy's, can anyone give me this info please
    Apr 2006
    Leicester
    240/aa/a on pilot premacy is this better or worse than the sumo's
    Lincoln
    michelin Sumo
    Treadwear 240 Treadwear 360
    Traction AA Traction AA
    Temperature A Temperature A
    see http://catalog.dmwork.ru/catalog1_1/...lotprimacy.pdf and
    Apr 2006
    Leicester
    so it looks good then, and i could get all 4 done for roughly the same price as i michelin (slight exageration) but you get the idea
    Apr 2006
    Leicester
    i had the sumo's fitted today, i just have to say what a great service www.valuetyres.com (broughtfrom), selecttyres Loughborough (fitted) all for the princly sum of £114 bargin, better TTT ratings than my pilot premacy
    Regular Member Eddie Dee's Avatar
    Feb 2007
    BELFAST
    Thumbs up sumos
    Let us know how ur gettin on with them mate thinkin of gettin a set myslf thanks
    4 for £114
    eeek, must be made of cheese
  3. More tyres....!
