Results 1 to 10 of 11
Thread: New rear hub assembly - where from?
    Nr Cardiff
    Default New rear hub assembly - where from?
    Been trolling the web to try and find the best place for a new rear hub, apparantly the bearing on its own can't be changed. Typical consumer society ****e.
    If you've bought one before, where from and how much did you pay?
    Thanks peeps.
    genuine VX £140...
    i've seen them on ebay for £65 thou...SKF as well, so it should be a quality part
    Nr Cardiff
    Thanks for that, I can't believe that you just can't buy the bearing!
    Having some new rear tyres today so we'll see if that cures it first, if not new hub it is I guess.
    May 2006
    Mansfield
    Quote Originally Posted by Triple Trouble View Post
    Hi there ,
    Can I ask what problem sent you down the path of new tyres / new Hubs ?
    SJ
    Nr Cardiff
    A thrumming/drumming noise from the rear of the car between 50 and 65mph.
    Could be the tyres (it was before) but knowing my luck it will be the wheel bearings.
    May 2006
    Mansfield
    Thanks for the info,
    I'm started experiencing a similar noise on the Signum, starts at 30mph and goes away at around 50, sounds as if you are driving over cats eyes
    SJ
    Nr Cardiff
    Update for you, just changed the rear tyres and rear shocks (didn't "feel" right). The O/S shock had a leak. That was the tyre that was on the limiters, whilst the other had another 1mm or so of life left in it.
    Always change tyres in pairs so did them both.
    Driven it home tonight and the noise seems to have gone. Good value at £240 inc VAT for Yokohamas (235/40/18 91w) and a pair of shocks. IMHO.
    For those interested, you can get a bearing kit for £60 plus VAT from motor factors using SKF bearings.
    May save someone some cash in the future.
    Regular Member S888 SRB's Avatar
    May 2006
    Hemel Hempstead, Herts
    £60 + for a frigging wheel bearing!
    Could i ask what sort of mileage you're on?
    Nr Cardiff
    Am on 78 000 miles. The good news is that the noise has vanished with the new tyres so it was probably a combination of the leaking shock and worn tyres.
    I'm one happy bunny. Left me change to replace my glow plugs at the terrible price of £21, FOR A SET!!!! That's value IMHO.
  1. Rear hub assembly
    By GARY3306 in forum Parts for sale
    Last Post: 7th July 2010, 20:51
  2. Rear hub assembly
    Last Post: 8th May 2009, 12:59
  3. Rear hub assembly
    Last Post: 7th April 2009, 19:53
  4. Rear Hub Assembly
    By si1964 in forum Suspension, Wheels & Brakes
    Last Post: 31st August 2008, 18:43
