Thread: Rear Caliper \ wheel bearing
    Scotland
    Default Rear Caliper \ wheel bearing
    Hi, just looking for some advice regarding wheel bearing noise from NSR. I put the car ( 1.9 SRi 150 ) in to get the NSR wheel bearing check under warranty as it seems noisy. The garage concerned wanted £60 to adjust the rear brakes before they could diagnose if the wheel bearing was noisy. I thought you couldn't adjust brake disc's ? I know there is some adjustment on the handbrake, but it seems fine. Any advice would be great, thanks in advance
    Ashington, Northumberland
    Quote Originally Posted by dmcl View Post
    What a load of blocks!!! All they need to do is raise the wheel off the deck and give it a good spin with their lug close to the hub, just like any MOT tester does. Another case of the garage trying to rake it in. You don't usually feel play in these bearings but you can certainly hear the roughness. HTH m8
    ^^^^^ just what he said.... the vectra's rear brakes are auto adjusting and need no intervention by the garage..you're being fed a line..
    Scotland
    Thanks guy's,
    there is another dealership in the area, I'll just take it to them and hopefully they won't try the same trick
  1. rear wheel bearing
    By Billythebubble in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2011, 19:19
  2. Rear wheel bearing/hub help
    By daviem-rfc in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 23:38
  3. rear wheel bearing??
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 22:14
  4. Rear wheel bearing
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2006, 16:23
