Results 1 to 10 of 20
Thread: would a failed shock absorber cause bad alignment on the rear?
    Cirencester
    Default would a failed shock absorber cause bad alignment on the rear?
    simple as above for when i go in to my dealer at 8am this morning?
    as my camber and castor are about 3 degrees out
    YES or NO
    Ta muchly
    in a word no....the alignment is down to how the arms are set when it left the factory...make sure they use a 4 wheel laser ligner to accuratly set the car up this time, if it's not been touched since it left the factory it could very well be out..
    Ashington, Northumberland
    No. Shock absorbers job is just to keep the tyre in contact with the road. It will not effect wheel geometry at all mate
    EDIT Marks fastest finger first lol
    Cirencester
    its never been done. had new tyres put on the rear GSD'3s a little while ago and i asked for a 4 wheel alignment check and the camber was out 3.3 degrees and the caster was about 3 degrees out, the tyre place wanted &#163;100 odd to correct it.
    Cirencester
    so a combination of a really bouncy rear end (failed shocks) and incorrect geometry will cuase a loose rear end "oooo arr ?
    Quote Originally Posted by jonr View Post
    its never been done. had new tyres put on the rear GSD'3s a little while ago and i asked for a 4 wheel alignment check and the camber was out 3.3 degrees and the caster was about 3 degrees out, the tyre place wanted £100 odd to correct it.
    Yea that'll see your tyres off quite quick
    Cirencester
    Gary, could i get VX to do the geometry adjustments for me FOC? as its never been touched by anyone else
    Ta
    it's unlikely that they will do it FOC, most tyre and exhaust places only charge around &#163;40 down here to do it..
    Cirencester
    okey dokey mark. when i push down on the front of the car it falls then rises, with a bit of resistance, however the rear i can bounce? defo shocks as i dont wanna look like a plank when they tell me its not lol
    If there's no resistance to the bounce and it keeps bouncing then yes, shocks m8
  1. 2.0t shock absorber help
    By stefan7153 in forum Engine & Drivetrain
    Last Post: 8th March 2011, 21:17
  2. Shock Absorber Help
    By Skinner in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2010, 23:23
  3. Rear Shock Absorber knackered at 32k !
    By 742-xx in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2008, 11:56
  4. Rear shock absorber, free to good home
    By muffking in forum Parts for sale
    Last Post: 3rd February 2007, 21:21
