Thread: Voltage Drain???
    Ex-Staff Full Member Mark The Cabby's Avatar
    Feb 2006
    In a house
    Vehicle : Ford Mustang
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    Default Voltage Drain???
    Guys,
    Is it possable for a install to drain so much voltage at high volume / output that it forces the ECU to recive faults that may cause partial shut down???
    It's Mustang time...
    not really???....had your alternator output checked if you think you have a drain??...get that and the battery checked out 1st mate..it's about the only way the stereo system and the engines ECU's..
    Feb 2006
    In a house
    Trim : GT
    Engine : 5.0 V8
    Year : 2016
    Though so Mark, Was just trying to find a cause for my spot of bother a few weeks ago and i remembered i had the dvd pumping quite alot...
    Regular Member graham a's Avatar
    hull
    i get this on ships electrics mark,most of the time it is volt drop,but with the canbus engines it is spikes that can shutdown a engine.if you have a volt meter,just check the voltage at the install to see if it does drop when you wack the volume up
    Here, there and every where!
    That's the reason a lot of "boy racers" have power caps to stop the dips and peaks in power m8 Also gives better sound quality too.
    See HERE
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by Caterman View Post
    See HERE
    I must be a Boy Racer then Tony?? I have a capacitor fitted in the boot.
    http://forum.vectra-c.com/showthread.php?t=23240
    Opps! Sorry Ian
    Regular Member SignumPhil's Avatar
    Luton, Beds
    I've seen odd things happen when there's a really big drain on the electrics (I'm thinking of a friend's Volvo V70, trying to jump start a Rover 400 Diesel that hadn't run for a few months), but I wouldn't expect a stereo to pull over 300 amps!
    Phil
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    In my 2000 Colt when the music was banging you could feel the engine slow up a bit, prob a mixture of alternator drag & low voltage to ecu.
    Vectra is fine, but i do have the aux battery in the boot doing the amps.
    member of the smoke patrol 230bhp+
    id look at the alternator first
    there was a call back on some of them maybe you may have one of the recalled alternator
  1. Cdti voltage ?
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2012, 18:26
  2. Battery Voltage
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2012, 17:14
  3. what voltage is the cig lighter
    By bunsen1 in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2011, 07:29
  4. What can cause a voltage drain...
    By Penfold101 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2010, 19:17
  5. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
