Thread: flat spot
    Regular Member surreyl31's Avatar
    Feb 2007
    somerset
    Default flat spot
    I put a k&n cone filter on my 53 plate 1.8 ls about five months ago. over the last month i have devloped a falt spot at about 1500 - 2000 rpm, have heared that this could be the cause. Is it true because never had a prob with any other car i had.
    it COULD have caused a problem with the air flow meter..but it's a COULD and it would cause that flatspot if it was an error..
    Feb 2007
    somerset
    had it serviced last week no fault codes how would i test if it was the meter
    Only really by susbstitution with a known good MAF sensor.. but they're not cheap.. Which engine do you run???
    Feb 2007
    North west
    could be the heat under the bonnet affecting it ?
    that would affect it across the rev range..
    Feb 2007
    somerset
    i run 1.8 122 bhp
  1. Flat spot :(
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2012, 19:06
  2. Flat spot
    By marc vectra sri in forum The 'Off Topic' room
    Last Post: 12th August 2012, 19:38
  3. flat spot but different
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 28th July 2012, 11:40
  4. possible flat spot?
    By andreitone in forum Vectra C / Signum Troubleshooting
    Last Post: 7th August 2009, 15:04
  5. Flat spot!
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 09:43
