Thread: How to remove rear lights?
    Tyneside
    confused How to remove rear lights?
    I've been searching to try and find out how to remove the rear lights but cant find a thing. Any help is greatly appreciated.
    Cheers in advance.
    Regular Member Damian's Avatar
    Market Drayton
    If it's a pre facelift hatchback then if I remember there are three nuts behind each of the light clusters holding them on.
    It was quite fiddly in the cubby hole with a spanner, I think it is one at the top ant 2 towards the bottom
    If it's a facelift or an estate then I am not sure, I would have thought they would be the same method though
    Tyneside
    Cheers Damian its a pre facelift so that answers my Q.
    Thanks a lot .
    Regular Member mickeyc's Avatar
    Over there between the land and the sky!
    just make sure you don't drop the nuts!!!
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    yep definastely 3 nuts per side. one top center one bottom left and one bottom right.
    Fddley but i found passanger one harder to do..
    Market Drayton
    Quote Originally Posted by mickeyc View Post
    The sounds of experience there !!!!
    Quote Originally Posted by mark1319 View Post
    Thanks a lot .
    No worries
    Quote Originally Posted by lee_eardley View Post
    I found that one easier being right handed, driver side was a pain for me, each to their own I suppose
    Quote Originally Posted by Damian View Post
    All I can say is that everyday I thank God for magnetic screw drivers!
    North West
    very quick n easy to do
    Unplug the lights connection inside the boots behind the lights.Then just undo the bolts.
    Oposite way to refit
  1. how do i remove seal on facelift lights
    By gazza3009 in forum Styling
    Last Post: 11th June 2009, 21:56
  2. Remove Fascia from Fog Lights
    Last Post: 12th November 2008, 19:51
How do I remove vectra c rear lights
